Question about Garden
I HAVE POULAN 2150 CHAINSAW IT WILL CRANK WITH CHOKE PULLED OUT IN ON POSITION BUT SOON AS I PUSH CHOKE IN TO OFF POSITION SAW CUTS OFF . I REPLACED FUEL LINES AND TANK FILTER AND PRIMER BULB
    Scholar:
  • 136 Answers
Try testing it with a known good carb. The float and needle may be worn out. Since it starts, it is obviously a fuel problem and not an electronic one. Or if you have the means, buy a new carb.
Posted on Nov 23, 2013
3 Suggested Answers
  • 149 Answers
SOURCE: poulan 2150 w/ walbro wt324 carb fuel line reassembly
the fule line that comes from the filter/ pick up will go straight to the nipple usualy the one closest to the middle of the carby.
the other hose comes from the carby to the in or **** side( punp it you can feel it)of the primer and then goes to the tank that is the return/ prime, nothing is conected to it in the tank. if you have the carby one the wrong way around it will not prime. just swap them over..
Posted on Jan 12, 2009
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
How do I cold start a poulan kd100 chainsaw
prime it and with switch to off position pull rope 3 or 4 times . turn switch to the on position and pull the rope again with choke pulled out .
Aug 08, 2016 | Poulan Garden
Starting a poulan 18 inch widthing chainsaw
Start by filling the fuel tank with a fresh mix of 50-1, fill the chain oil tank with non fling chain oil, sit the saw on the ground with the bar away from any obstructions, engage the chainbrake, switch the ignition on, press the fuel bulb as many times as it takes to 3/4 fill the bulb, pull the choke out, this should also engage the fast idle, crank the engine until it fires once, it will not run on choke, it is importent at this point you must push the choke back in, now crank the engine until it runs, flick the trigger to allow the saw to idle.
Sep 28, 2013 | Poulan Garden
Diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
Jul 05, 2012 | Poulan Pro Chain Saw 46cc 20"
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Mar 19, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have difficulty starting my Gardenline 49.3cc chainsaw. Please let me know what the correct starting proceedure is.
Genral starting procedure on a chain saw is as follows, put fresh fuel into the fuel tank, top up the chain oil tank,switch the ignition on, if the saw has a half throttle position on the trigger lock this, if the saw has a primer depress this as many times as it takes to 3/4 fill the bulb, pull the choke fully out, if it has a deco valve push this in, now place the saw on the ground with the chain brake on and crank the engine ( always have the saw body between you and the cutter bar,NO left hand starting, NO drop starting ) the engine will only fire once on full choke, do not continue to crank engine after the first fire or you will flood the engine, push the choke back in, crank the engine until it fires up and runs,release the chain brake and blip the throttle to release the half throttle device.
Jan 22, 2011 | Garden
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
