Question about Schylling My Secret Safe with Alarm
Reset combination on my secret safe - Schylling My Secret Safe with Alarm
Lsot combination
Hi RevelFreeman
Two directions you can go.
If you're the original owner of the safe, and you never changed the combination from when you got it, look in your documentation, call the manufacturer, or look online for 'My Safe Model / Type Default Factory Combination. That may well get you in, though you are strongly urged, in the process, to then change the combination and save a copy in a secure place. This process has ample history, including Richard Feynman cracking the safes with nuclear secrets during the Manhattan Project. It's also a TV trope, and well known to both the white and black hat types.
If you changed the combo to something else, your best bet is to dig up documentation that you are the owner of the safe (or, if it's built in, the owner of the house) contact a locksmith and talk to them about your predicament. No reputable locksmith will want to touch it if there's any question about whether its your safe and contents.
Hoping this helps, and Good Luck
D
Dec 18, 2015 | Home Security
I can't open my bumil safe and the combinations i have are old and i think i keep getting them wrong, im not sure what to do.
Take it to a Locksmith. Most newer safes (15 years or younger) have a secret way to get inside, which the manufacturer is willing to reveal ONLY to a bonded-professional Locksmith. If there is no secret entry, then the safe will have to be drilled open (i.e. "destroyed"); and that too must be done by a locksmith because only they know _where_ to drill. Lastly, If you have electronic code entry, try installing new batteries, and retry your combination codes. Ps... I am a locksmith. I know what I'm talking about.
Oct 14, 2015 | Home Security
I have a Sentry Safe MSW3517 and can't remember
Not possible only u can do it with the dustruction of the combination lock pad.U ever register this safe?Yes?U can call the company up they'll tell u ur combination,because it a requirement,when u register it or they'll sent some one out for there master secret combination they get it open for u.
Aug 06, 2011 | Safe International Sentrysafe Security...
I have forgotten the combination to my safe. Is there anyway to retrieve the combination?
Only way.Did u register the safe product when u buy this thing,yes call Honeywell.They will give u their secret master combination numbers if they trust u or they'll sent out to u a safe tech. service rep. to ur house used that combinations.
Jul 14, 2011 | Honeywell Safes 2087 Waterproof Fire Safe...
I lost the instructions and don't know how to unlock using "original code" and how to create a new code
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
I dont know how to open the lock its brand new????? They failed to give me instructions when they attached to the bike
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
etc.
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
combination.
Oct 11, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
Try this....
Post. (Figure 1)
etc.
original position.
combination.
Sep 16, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
Need to open a Sentry keyless combination safe
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Apr 10, 2009 | Sentry Fireproof Safe
Query on electronic safe
go to the electronic shop and ask for assistance.
May 12, 2008 | Dryers
Schylling My Secret Safe with Alarm Logo
223 people viewed this question
Top Schylling Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Schylling Toy Expert? Answer questions, earn points and help others
