Question about Hudson Reed Minimalist Thermostatic Bar Valve & Pro I Telescopic Kit
Hot water has no preassure
Got pressure to valve but only a dribble when turned on
The hot water barely comes out of my washing machine. The cold water is fine
It seems to be that the HOT line is clogged, You need to flush out more with high pressure or by removing the hot line and reverse flushing.
Also check for dirt accumulation at the hot line input and valve.
Jan 23, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Rheem Steller natural gas hot water service. There is a continuous dribble of water from the pressure valve overflow, even when the heater is not heating. I have tried easing the valve a few...
Yes, Turn the knob on the gas valve to off. Turn off the incoming water line into the water heater. If you have a valve on the outlet turn it off too. Open the drain at the bottom of the heater to drain a little water from heater. You can then lift the lever on the temperature/pressusre relief valve to let a little air in to release the vacuum and let the tank drain. If the relief is in the side let it drain a bit longer so the water level is below the outlet. Be sure to re-install the down pipe on the relief valve on the new valve. You should drain the a few gallons of water at least once a year from your heater, and you should exercise your temperature relief valve once a year to be sure it will function. If your new valve leaks suspect your temperature control allowing the water to get too hot.
Oct 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have an Ideal 24mini with a mega flow, I have water dripping from my discharge pipe. But the preassure gage keeps rising up even if I release some preassure freom the heating system. Iv checked the...
Hello It could be a bad/defective EXPANSION tank if it(valve) leaks when the burner is running and the pressure rises at the same time .Otherwise swap the valve as they can wear out.
Sep 21, 2010 | Heating & Cooling
Hi the cold water just dribbles into the tub. if I
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Washing Machines
Problem: the cold water just dribbles out when filling the tank and it takes forever to fill the tub.no problem with the hot water flow.
If you have water pressure to the cold inlet valve and the valve's filter is clear, you probably have a failed inlet valve...Replacing the cold valve should fix the problem..Not a big or expensive job..Good luck....Nomess
May 20, 2010 | Washing Machines
Hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Nov 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Dribbling water when trying to fill up
Turn off faucets for hoses to washer. disconnect hoses at washer, noting which one went where first.. Hold end of hose in washer tub and turn on faucet. If it comes out strong, check the filter screens in washer inlet valve where hoses connected. DO-NOT remove these screens. If you do it can cause flooding by allowing grit to hold open valve. Clean screens without removing them by scraping with small screwdriver and flushing with water.
Nov 21, 2007 | Washing Machines
Hudson Reed Minimalist Thermostatic Bar Valve & Pro I Telescopic Kit Logo
545 people viewed this question
Top Hudson Reed Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Hudson Reed Garden Expert? Answer questions, earn points and help others
