Question about Dewalt DW788 Heavy Duty 20" Variable Speed Scroll Saw: DW7881 Worklight
Where are the brushes in the dewalt 788 20" scroll saw? Mine keeps blowing fuses & I think the brushes need cleaned but don't know how to get to them
    Sergeant:
  • 206 Answers
Blowing fuses is not caused by brushes unless there is a huge spark show going on and if that is the case your armature will be trashed as well - the electronic module in that saw is notorious for failure and that is where I would start
Posted on Jun 19, 2014
SOURCE: i have a dewalt scroll saw the air hose came off
lo que pasa es que esta mal el boton de arranque conosido como resistencia bariable
Posted on Apr 20, 2009
  • 12 Answers
SOURCE: I have a 20'' dewalt scroll saw that will not start
If you are getting voltage then it is most likely the control board. You would need to take it into a repair service center and they would have to pull the whole thing down to repair.
Posted on Feb 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a Dewalt dw 705 miter saw.when you pull the
the armature needs to be cleaned or it is possibly bad (open bars) They make a special cleaning stick called a commutator stone that you might be able to purchase at a local repair shop. If you are not comfortable trying this I would recommend taking the saw with you, To clean properly you have to remove a cover and have the saw running, I would also check for proper movement in the brush tube allowing the brush to freely contact the armature. Let me know if you need more assistance and I will try and help.
Posted on Nov 13, 2009
sonicboomele
  • 1557 Answers
SOURCE: I lost my manual to my Dewalt DW788 Scroll saw.
he-manuals.com/dewalt-dw788-manual/ -
this should get you back on track
good luck
Posted on May 15, 2010
  • 65 Answers
SOURCE: how do i replace brushes on dewalt table saw
unscrew brush cap on each side of motor and pull brush out
do it reverse with new one
Posted on Nov 23, 2012
My DeWalt scroll saw will not turn on. Have checked outlets and would like to check fuse. Not sure how to open fuse hatch without risking damage. I keep all manuals but can't locate one for this saw.
take a small screw driver and push down on the clip at the top of the fuse holder, it should open and you cans ip iy out. be sure and replace the fuse with a 3 AMP FAST BLOW ( not a slow blow) oldcodger2
Sep 22, 2011 | Dewalt & Variable Scroll Saw
Dw364 looks like an arc welder where the brushes are , blows breakers and electric brake doesn't work DEWALT WILL NOT ASSIST
could be a couple problems, first unplug tool and remove brushes, I would assume they are burnt or short, next while turning blade by hand look at the commutator to see if there are raised bars or extreme discoloring, if so the armature needs replaced. I would start with these 2, after installing new brushes you probably have to clean the commutator. Let me know if you need more assistance.
Mar 31, 2011 | Dewalt Saws
My saw sparks more than normal at the brushes. I need help solving this problem
I would get an airhose and blow the motor clean of any sawdust first and then i would check the brushes and brush springs. just a few ideas. Jeepfxr
Nov 30, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
I have a Dewalt dw 705 miter saw.when you pull the trigger the saw starts for a second and then shuts off. I have replaced the brushes and it worked for a few minutes and quits. the brushes do not seem to...
Nov 10, 2009 | Dewalt Saws
No power it just died, what could be the problem? We tried other outlets and it still won't work.
CHECK FOR ANY BREAKS OR WEAR IN CORD , IF NONE IT MAY BE THE CARBON BRUSHES ARE WORN OUT .
Oct 28, 2009 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Dewalt flip saw keeps blowing fuse
common problem with this saw is the brushes when worn down to about half inch, won't go into the brush holder any further and starts to arc against the commutator. eventually the heating will burn out the commutator. a replacement armature will cost you $75 plus shipping.
Oct 20, 2009 | Dewalt DW746X 10" woodworker's table saw...
Metal chop saw blows breaker
Is there anything else running while you are cutting? If not is the breaker 15 amp or 20 amp. If its 15 amp, I would change it to a 20 amp breaker. Make sure the wires are thick enough to handle the extra load. If this isn't the problem check the cord from the saw to the outlet.
Good luck!!
Jul 28, 2009 | Dewalt Chop Saw D28700
Dewalt DW788 Heavy Duty 20" Variable Speed Scroll Saw:  DW7881 Worklight Logo
145 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
