Question about KitchenAid Refrigerators
Kitchenaid fridge running loud after being in frozen garage
Will it improve once it warms up or has it been damaged?
    Champion:
    Habit-Forming:
  • 275 Answers
Run it for a while & find out, never heard that problem before.
Posted on Dec 02, 2013
4 Suggested Answers
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
Sea Breeze
  • 4654 Answers
SOURCE: freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Posted on Oct 02, 2009
Testimonial: "thank you , i will try it."
mangofruityj
  • 673 Answers
SOURCE: fridge is warm
Adjust the cooling knob inside the fridge according to the outside temperature.
Posted on Oct 27, 2012
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
The refrigerator side is cool, but not cold. The freezer side is frozen, but melting. The ice in the ice maker melted, but created one big ice cycle that has not melted. The fan underneath is running,...
I just ran into this problem this year. Is it very warm underneath your fridge? If you remove the cover in the back, you may find that you compressor is so hot you can't touch it. You can first try blowing out your cooling fins in the back of your fridge. A fan is connected to it and it should be next to the compressor. For my case that did not work. I then replaced the fan for the cooling fins and now my fridge works fine.
Nov 10, 2012 | KitchenAid KSRS25FG
II have a model 5707591 side by side in my garage.as long as the ambient temp is 35-40 F everything works great.when it gets below that the freezer cant keep frozen.temps will rise to 25 F while the fridge...
the thermostat isn't cycling because it's to cold in the garrage,the machine isn't calling for cold air because the garrage is so cold so the fridge isn't gonna run until the temperature starts to get warm and then the fridge will start again to keep it cold.put some heat in the garrage and it will run fine
Feb 27, 2011 | Kenmore Refrigerators
Model was bought 1/92. Ice cube maker not working although we hear a churning sound that seems to signal something's trying to work! What do you think? KitchenAid KBRP20EMSS Bottom Freezer Refrigerator
Those ice makers get stuck from frozen ice portions. Try feeling around to see if anything in the icemaker is frozen up or any foreign object. Please do this with fridge unplugged. If you can't find any frozen or other obstruction then use the hair dryer to defrost the ice maker. This is only a guess from past experiences. My kids once put pop cicle sticks in the ice maker wanting to make ice cube on a stick. Goodluck Google burdfrenzy
Nov 26, 2010 | KitchenAid KBRP20EMSS Bottom Freezer...
Just moved fridge - very hot down the middle
Good day,
Common at the beginning of start up, if the machine is warm. There is a heater there and once the machine is at temperature, it will revert back to just being warm.
HOWEVER, There is a cooling fan motor located at the bottom back rear of the machine by the compressor. If for any reason it is blocked and cannot run, you will experience the same problem and if allowed to go too long, damage the compressor.
This should be checked as soon as possible.
Mar 28, 2010 | KitchenAid Superba Architect KSCS25INSS...
Fridge not cooling...freezer works fine.?
Have you checked the damper at the top left hand side, could be frozen - take it off thaw it out and replace. The freezing could have damaged the unit though.
Jul 19, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchenaid side by side too cold. Freezes everything.
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Samsung refrigerator freezer not freezing
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
Mar 09, 2009 | Samsung RB215LASH
Condenser coils frozen over
Sounds like the defrost heater is not working. Burned out heater or bad defrost thermostat.
Mar 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
46 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
