Question about CAS DLP-50 Thermal Label Printer
Formating the printing receipt - CAS DLP-50 Thermal Label Printer
How to upload eBay receipt to third party
What format is the receipt is it an email message is it on your screen. Is it a PDF file. Most likely right click on receipt link and select save target or save link.or save link.. Or function FN then Print Screen on keyboard and then open paint program and paste off clipboard and crop screen print and then save file. Then attach file to an email message and send to third party.
If it is an email message just select Forward in email options and email to third party.
Sep 05, 2014 | Computers & Internet
Epson iii & 4 printers prints slow
Try printing something that is formatted properly to fit on a receipt roll printer. the Windows test page will always be slow on a receipt roll printer, because it is formatted for 8-1/2" X 11" pritners and contains graphics. I suspect that actual printing will be fine.
Jun 30, 2010 | Epson TM-T88III (C420863)
Customber recipt check doesnt print logo after i set it up to do so... only prints logo on full professional format on the printer. i checked the printer settings on the software and checked "print logo"...
What version of RPE are you using and what model receipt printer? Version 11.5 with an Epson thermal receipt printer usually requires a special logo designed for that model printer. Not just any jpg or gif graphics file. Epson will create file for you, but it is pricey, around $200 last I checked. I'm not sure if the latest version 12 has a better fix for this or not. And you are right, there is no print preview on receipt printing. Contact me if you need tech help. sysadmin@ccybernet.com
Jan 30, 2010 | Pc America Restaurant Pro Express
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
Oct 27, 2009 | Sharp XE-A404 PC Desktop
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
function is in the “ON” status."
Sep 24, 2009 | Sharp XE-A404 PC Desktop
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
OFF.
All the best!
Greg
Aug 01, 2009 | Sharp XE-A404 PC Desktop
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
Epson TM-U220D Receipt Printing Problem
mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
Oct 21, 2008 | Epson TM-U220 Matrix Printer
CAS DLP-50 Thermal Label Printer Logo
Top CAS Office Equipment & Supplies Experts
jasbo
jasbo
Are you a CAS Office Equipment and Supply Expert? Answer questions, earn points and help others
