Question about Magnavox NB954 Remote Control NB954UD
Magnavox NB954 remote green netflix button doesn't work anymore
All of the other buttons work
Why am I unable to hit the red Netflix button on my Roku remote and have Netflix come on my TV. Nothing has changed, I haven't unplugged anything in the back of the TV or receiver, have replaced the
There is a good chance the remote is defective. You may try installing Netflix from the channel store and and using it like other channels. The other thing would be to uninstall Netflix and then reinstall it. It is possible the info for login is corrupt or the Netflix contact on the remote is bad. Hitting the reset button should not cause any harm but will restore the remote to it's original state. If you know someone with another Roku, any model , try that remote to prove it. Good Luck!
Dec 11, 2014 | Roku 1
Ok/select doesn't work with magnavox dvd player
Hi, make sure you Comcast remote is in the "DVD" mode before attempting to work the DVD features. If it is still not working. You need to reprogram your Comcast remote to a different Magnavox DVD code because the code it is currently set for not fully compatible. If you need the instructions to reprogram your Comcast remote go here. If you would like to purchase a new Magnavox DVD player remote you can also search on Replacement Remotes for your DVD player's model number located on the back of the unit. If they have it, it will show for purchase.
Sep 03, 2012 | Universal Remote Control Remote Control
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I cannot connect to netflix. it just shows a black screen when it loads netflix and it will not load anymore. I want to know how to set the vizio blueray player back to factory settings to see if that...
on the remote that came with the player, should be a settings button and somewhere in those menus should be a reset to factory settings option
May 05, 2011 | Computers & Internet
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 08, 2010 | Televison & Video
I CANT GET OFF THE SET UP SCREEN , MANGNAVOX 47" TV, NO UNIV. REMOTES HAVE WORKED, PRESS THE GREEN BUTTON TO PROCEED?
The TV was turn ON for the first time or the TV reboot/reset.
Universal remotes are not as "universal" as we like them to be. They only control a very, small amount of options for the TV.
You'll need the remote that came with the TV to fix this problem because it has the special RED, GREEN, YELLOW, and BLUE buttons you need.
If you don't have the original remote, you can get one at this web site. It's the best price going right now. $29.95
http://www.magnavox.newremotecontrol.com/catalog_item.php?catnum=996500043780
Jun 01, 2009 | Toymax Magnavox 47MF437B 47 in. LCD TV
Magnavox NB954 Remote Control NB954UD Logo
53 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
