Question about LG HT905TAW Home Theatre System
SOME SPEAKERS NOT WORKING
REAR WIRELESS SPEAKERS DOENS'T WORK, BLUE LIGTHS BLINKS BUT LATER TURNS RED, TRIED UNPLUG UNITES FROM POWER AND PUSHED STOP AND MUTE TOGETHER BUT NOW ONLY CENTER AND SUBWOFFER ARE WORKING
alwayzlove11
  • 3 Answers
SOURCE: No sound
i suggest that u take that box of cardboard back to the store that you got it from. or get some answers from them.
Posted on Mar 30, 2009
  • 3 Answers
SOURCE: center speaker and wireless rear speakers have no sound
I had the same issue, but apparently...it's not an issue. What I discovered is that the system was fine, but the station I was watching didn't broadcast in 5.1 surround sound. Therefore, only the front speakers will have sound. Try putting a dvd in, or listening to a gameing system through it. If you don't have sound after listening to something that puts out full surround sound, then you know you have an issue.
Posted on Aug 13, 2009
SOURCE: Have LG bluray home theater system model # LHB975,
Try to reset the network settings ..
Select [Connection Setting] option in the [Setup] menu then press ENTER
The [Connection Setting] menu appear on the screen. Use up/down arrows to select [Wireless] and
press ENTER
Selects [Yes] and press ENTER (to continue. The new connection setting
resets the current network settings.
Reconnect the wireless receiver ..
Turn on the main unit and turn off the wireless receiver.Press and hold x (STOP) on the front of unit
and MUTE on the remote control. "REMATE" appears in display window.Turn on the Wireless Receiver
Posted on Mar 19, 2011
hoty252000
SOURCE: i have a lhb975 5.1
I also have the lg lhb975 home theater i went through everything sugested by other people and web sites. i talked to an electronics expert that is a friend of mine, and we both went through all the steps again. just to make sure i did not miss any steps. the solution that we came up with is that the wireless card inside the main unit is defective, and that it should be sent back for repairs if under warrenty. if it is out of warrenty it should be taken to a repair shop. to have the card replaced and reset.
Posted on Mar 11, 2012
SOURCE: My two wireless speakers are not working. the
I am having the same problem with my LGHB905TAW. Called local support without any feedback... I think this is the bug in design phase.. Search around the internet but without any positive result...
Posted on Apr 23, 2012
Wireless speakers not linked
Have you attempted to push the search button on the back of the receiving unit? Power down the transmitting unit and the receiver and reset the signal button on the rear unit after re-powering both units. Power surges seem to fry components on the rear unit. surge protection is a must on these things.
Oct 20, 2012 | Samsung Receiver Ah63-02058u For Ht-c650w...
BLINKING STANDBY LIGHT AND NO POWER
there is a possibility that the power switch capacitor has bubbled or leaked a remedy is to unplug the unit from the outlet for at least an hour then try to power it back on.
i will try to look for more information about other work-around's or which of the other parts are defective or almost defective, that is causing the problem.
Jul 30, 2008 | Sony KP-46WT520 46" Rear Projection...
SAMSUNG SWA5000 Wireless Receiver Module stopped working **help help**
HiI have the same problem, have you found the solution?
cheers,
Dec 29, 2011 | Samsung SWA5000 Wireless Receiver
Reconnect my wireless lg w95 receiver to my blue ray after it was unplugged
Wireless speakers connection
LED indicator of wireless receiver
LED Color Operation
Blue - The Wireless Receiver is receiving the signal of the wireless transmitter.
Red - The Wireless Receiver is in standby mode.
Off (No display) - The Wireless Receiver is turned off.
Initial setting an ID of wireless receiver
1. Connect the Wireless Receiver and the rear speaker (right, left) with the speaker cables.
2. Connect the power cord of the Wireless Receiver to the outlet.
3. Turn on the main unit and Wireless Receiver: The main unit and wireless receiver will be automatically connected. "MATE OK" appears in display window. Setting an ID of wireless receiver When the unit is manufactured, the ID is already set. If an interference occurs or you use a new wireless receiver, an ID should be set
again.
1. Turn on the main unit and turn off the wireless receiver.
2. Press and hold x (STOP) on the front of unit and MUTE on the remote control. "REMATE" appears in display window.
3. Turn on the Wireless Receiver. A new ID is set.
Nov 23, 2011 | Televison & Video
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
MY 3 PIECE GEMMY CHRISTMAS TREES STOPPED WORKING THE SPEAKER FOR MUSIC JUST KINDA HUMMS AND THE LIGHTS WILL NOT WORK
Here's what you do... This is for the trio christmas tree light show.
What you need.... small precision pointing tool.
On the largest tree base electrical box there is a push button. Press and release that button. A red led will flash indicating the box is in sync mode. turn the remote on and on the back of your remort, there is a small hole with the words reset over the top of it. Using the small precision pointing tool, press the recessed button and release. The remote will sync to the base unit. Walla!! Merry Christmas to all!!!
Nov 29, 2009 | Gemmy Toys
Logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Feb 27, 2008 | Logitech (980361-0403) Headphones
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
Power Problem? My DS55 red standby light blinks at me and won't turn on.
I agree with your diagnosis. If one channel quit and the unit now ocassionally won't output at all then the amp is going into protect. Have it serviced.
Sep 20, 2007 | Aiwa NSX-DS55 CD Shelf System
LG HT905TAW Home Theatre System Logo
22 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
