Question about Giagni Pullout Kitchen Faucet with Soap Dispenser in Stainless Steel PO14
GIAGNI diverter removal and installation instruction
How do you remove quick disconnecton 951-0620 hose?
The installation instructions show that the collar on each of the two flexible lines can be pushed/pulled back (away from the diverter valve) to release the lines. It is not that easy! I got my lines off and back on again without leaks, but I sure had to pull hard on that collar to pull the lines from the diverter valve.
Aug 28, 2014 | Price Pfister Plumbing
Our Giagni Andanti model LL800-BN bathroom faucet drips after water is turned off need to know how to make an adjustment to stop drip
Turn the water off. Remove the handle, usually has an Allan wrench screw on it. Take out the stopper unit and clean it. When you are done tighten it as you can without stripping it, Out it all back together and it should work. Sometimes you need to replace the washers or internal unit itself, but try this first.
Apr 16, 2014 | Giagni LL800 Andante Open Trough 1-Handle...
Replace diverter in 2 handle aqua source kitchen faucet
For a dual-handle Aquasource kitchen faucet with spray hose, the following instructions will afford replacement of the diverter. These instructions specifically refer to the faucet illustrated at http://pdf.lowes.com/installationguides/6953123900358_install.pdf, and the diverter identified as part RP70007 (item 14). Note the position of notches at the top of the diverter and around the rim of the base of the diverter, either of which can be used to leverage a tool to rotate the diverter out of position. Caution: The diverters on older faucets may be exceptionally brittle and thus very difficult to remove.
1. Using a pipe wrench or similar large-mouth wrench, unscrew the base of the faucet. Wrap the base with a cloth or other protective material to prevent scratching during the process of unscrewing. The base unscrews in a counter-clockwise direction.
2. With the base removed, remove the faucet. Note that a small amount of water may drain from the faucet when removed.
3. Removal of the base reveals the top of the diverter, which is a white, plastic cylinder approximately two inches long with copper stopper in the bottom. Insert a wide, flat-blade screwdriver across the notches in the top of the diverter - but be *extremely* careful. A faucet that has been installed for some length of time may have an exceptionally brittle diverter. If the upper shaft of the diverter breaks, a pair of needle-nose pliers may be used in the notches around the *base* of the diverter. Carefully rotate the diverter counter-clockwise to remove it.
4. Insert the new diverter and screw it into place in a clockwise direction. Apply a wide, flat blade across the notches in the top of the diverter to apply slight additional pressure to tighten the diverter just beyond hand-tightness.
5. Re-insert the faucet.
6. Screw the base back into position, tightening as necessary.
7. Test the operation of the diverter by operating the cold and/or hot water faucets, then the spray handle.
Dec 24, 2012 | Plumbing
I purchased the Giagni pressure balance polished chrome tub and shower faucet with the square back plate from Overstock.com. The set did not come with instructions and the plumber is having trouble...
they are built to european standards. The differences will be in the threads and pipe sizing, requiring the use of adapters here and there to make everything screw together properly.
others have had this problem too.
if this is what you mean by trouble getting it installed.
Jan 07, 2018 | Giagni Home
Have Kohler diverter, GP 75878 but no instructions as to how it should be installed. Is it under sink where sprayer hose is attached?
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
Dec 20, 2010 | Kohler Model 10430: FortĀ® Single-control...
Ii need install instructions for Giagni Kitchen Pro Series Model KP50-PC
Faucet discontinued but:
Install pdf on Overstock.com listing for KP50.
Also, Giagni 888-560-5222
Aug 19, 2010 | Plumbing
Remote for Insignia diverter box needs reprogramed
Try removing the battery, pressing all of the remote's buttons, and installing a new battery. This will resolve most remote control problems.
May 19, 2010 | Insignia Digital-to-Analog Converter for...
Shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Nov 17, 2009 | Delta & Single Handle Shower Faucet
Water from shower head not hot
Depending on the brand, it can either be screwed out using a philips head screw driver or there is a small washer in the shower head that can be pulled out using a sharp pointed object. I use a dental pic to pull them out before I install them.
Mar 18, 2009 | Giagni F9 Fino Paper Holder Bathroom...
Giagni Pullout Kitchen Faucet with Soap Dispenser in Stainless Steel PO14 Logo
173 people viewed this question
Top Giagni Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Giagni Plumbing Expert? Answer questions, earn points and help others
