Question about Konica Minolta Office Equipment & Supplies
Error code c2242 on Konica Minolta Press c7000
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
jqsababa967
  • 145 Answers
SOURCE: KONICA MINOLTA
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Posted on Nov 04, 2008
SOURCE: IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Posted on Aug 23, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
How to fix error code C0103
one of your paper draws not working check all for proper operation might have paper behind them
Jan 14, 2015 | Konica Minolta Konica BizHub Press C7000...
How to fix 2231 error code?
Could be one of these, start first with the Y drum
Anything else get a tech out power supplies and printer control boards are serious money$$$$$$$$$$$$$$$
• Printer control board
(PRCB)
• Drum motor /Y (M14)
• Encoder sensor /Y1
(PS81), /Y2 (PS82)
• DC power supply /2
(DCPS2)
• Drum Unit /Y
May 18, 2014 | Konica Minolta Konica Kit For Bizhub Press...
Konica minolta bizhub 7000 controller doesn't turn on
Turning the Power On or Off - Konica Minolta Online Manuals
manuals.konicaminolta.eu/bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
[PDF]C7000/C7000P/C6000/C70hc/ C6000L
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
Feb 15, 2014 | Konica Minolta Konica Kit For Bizhub Press...
Error code c-DOE1
Hard drive failure or not connected
Jan 14, 2014 | Konica Minolta Konica Kit For Bizhub Press...
Konica C7000 stopped printing C-0213 error code came up
The paper exit pressure
home sensor (PS10) does
not turn ON within a
specified period of time
after it turns OFF.
one this mite be bad:
AC drive board (ACDB)
(PRCB)
• Paper exit motor (M54)
• Paper exit pressure
sensor (PS10)
recommended you have a tech look at it believe the tech bulletins on this problem
Jan 07, 2014 | Konica Minolta C6500 C5500 C6501 C6000...
Does anyone know how to reset counters on bizhub c7000?
Enter in the service mode and select counter mode and reset a counter to selected parts.
Apr 05, 2013 | Konica Minolta Konica Kit For Bizhub Press...
Error code c2801
Maximum density correction problem.Clean the AIDC sensor located under OPC drum.
Mar 19, 2013 | Konica Minolta Konica Kit For Bizhub Press...
C-2813 error code in c-6000 help us
2813...related to cyan.
Excess charge on drum beyond the specified value.
Solutions...1) swap the drps board with yellow or with other color unit and see weather code is changing .if it is changing the drps board is the culprit.
2) clean the HV contacts located behind the processor unit.
3)clean the IDC Sensor unit
4)change developer
5)caronas
Oct 27, 2012 | Konica Minolta Konica Kit For Bizhub Press...
502 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
