Question about Kitchenaid Mixer Kpca Pasta Angel Hair Cutter Roller
KPCA replacement parts
Need nylon gears for angel hair cutter
Where can I get a manual?
[PDF]Download - KitchenAid
www.kitchenaid.com/.../KPCA/Use%20and%20Care_EN.pdf
KitchenAidKitchenAid® Pasta Roller and Cutter Set (KPRA) or the Pasta .... We have provided many important safety messages in this manual and on your appliance.
Sep 30, 2015 | Kitchen Appliances - Others
Where can i get gears for kitchenaid pasta roller
Not a solution, just want to echo the problem. There are solutions for the shaft, but when I opened this up I found a stripped nylon gear attached to the shaft. Kinda sucks: I recently replaced the nylon worm gear in the mixer, now I have to do the same in the spaghetti cutter. I can't find the part or any mention of it anywhere.
Jan 17, 2013 | KitchenAid Pasta Roller / Cutter Set
KitchenAid KPRA Brass input shaft sheared. Need a replacement
The "brass input shaft" is designed to break in the event of too much torque being applied; it acts as a shear pin. For safety considerations, I would be careful what I used to replace the shear bolt/shaft. Failure of the shear bolt is necessary to prevent more serious damage to either: 1) the mixer, 2) the pasta attachment, and perhaps most importantly 3) the object stuck in the pasta attachment (think of ingested clothing, hair, fingers, etc). Unfortunately, KitchenAid refuses to supply replacement shear bolts (and I couldn't get an answer as to why); however, they seem pretty good about replacing the attachment under warranty. But logic dictates that a part, such as a shear pin, that is designed to fail, will have a high probability of breaking long after the warranty period has expired. To that end, I have machined a bunch of spare shear bolts to the same physical dimensions as the original part out of 5/16" brass hex stock. I would consider making some available to others in need at a nominal fee.
Mar 04, 2012 | KitchenAid Pasta Roller / Cutter Set
The nylon gears that drive the cutters are broken
This call is posted under Royal Shredders so assuming you have a Royal shredder give Royal a call at 1-800-524-0799 for parts assistance.
Oct 12, 2010 | Office Equipment & Supplies
Nylon gear has several of its teeth. 2 gears are
For parts advice call Royal at 1-800-524-0799.
Dec 10, 2009 | Royal 150MX Cross-Cut Shredder
The cutter of the blade assembly barely moves. Oster A-5 Turbo
this pin or Post is moulded to the body of the clipper they only require replacement if you can move the post, alternatively there could be wear on the nylon drive lever or the gear try packing with clipper grease.
Nov 10, 2008 | Oster 76076-040 Hair Trimmer
Motor runs both forward and reverse, but cutters don't turn
How about a hidden 7th screw? If you look at the sticker on the underside where the bar code is you may see a dimple like there is a hollow space under it. If you can't see it, rub your finger over it to find the hole. Just stick your phillips screw driver through the sticker to get access to this last screw. As for the motor working both directions but the cutter doesn't turn it is most likely a broken nylon cog on the drive gears within the white plastic housing at the end of the shredder. There are 3 or 4 gears - all nylon (plastic), my unit had one tooth completely broken off and the one next to it was worn. I am looking into finding parts but I'm not having any luck so far with local service centres. I have a call into the fellowes main 1-800 number to see if they can help. On reviews I have seen this is a common problem. One reviewer was told they use nylon to reduce noise, but of course it isn't going to last long, especially if you ever jam. Nice metal cutters but the weak link is the drive gears that you can't see.
Oct 16, 2006 | Fellowes P600C-2 Shredder
Kitchenaid Mixer Kpca Pasta Angel Hair Cutter Roller Logo
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
