Question about Sharp R-1482 Microwave Oven
How to uninstall from under cabinet - Sharp R-1482 Microwave Oven
Can you provide under cabinet mounting instructions for GE Microwave part WX4-A19?
To mount it under a cabinet, you have to have the under cabinet install kit; you'll find that here: Under Cabinet Mounting Kit WX4 A019 GE Appliances the kit does include instructions. You can't mount it without the kit.
Dec 12, 2015 | GE Microwave Ovens
How do I change the front exhaust to top exhaust on a Kenmore microwave/hood
In order to change the venting on the microhood you need to uninstall the unit and at the top of the microwave is the blower unit. Remove the cover, flip the blower and you should then see the fins on the motor, reinstall the unit under the cabinet and your good to go. I hope this helps, good luck
Mar 15, 2015 | Kenmore Microwave Ovens
How to uninstall a sharp 1502 microwave. We've removed two bolts on top through the cabinet and four screws in back under the mounting bracket. The microwave is still stuck in the back on the left.
We have the owner's manual at our site here, and it contains the installation instructions.
Dec 26, 2010 | Sharp R-1502 Microwave Oven
How to remove the old Tappen microwave oven model 56-2891 under the cabinet?
open the cabinet door above the microwave there should be four screws going thru bottom of the cabinet shelf holding it on to cabinet have a helper hold the microwave as you unscrew it
Dec 12, 2010 | Tappan Microwave Ovens
I NEED A 24 IN. WIDE COUNTERTOP MICROWAVE TO BE INSTALLED UNDER A CABINET. NO VENT NEEDED. I WAS NOT LOOKING FOR A DRAWER TYPE UNIT. I CANT FIND AN INSTALLATION KIT TO INSTALL ONE. THE ONLY KIT I COULD...
Sharp has a model 1214 that could work, but it is a little over 15" deep and will therefore not recess entirely into a 12" deep upper cabinet. I believe the install kit comes with it?
Jan 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need to know how to uninstall a GE spacemaker microwave oven model JVM250av001...any one out there know how..?
Put padding on the floor near by for a landing zone. Disconnect the power in the cabinet above. There are two screws in the upper cabinet that support the front. There is a wall plate that supports the back. When the two front screws are removed you will need to be supporting the microhood or it will fall. A strong assistant is nice to have. I like to have the stove out of the way so I can get under the microwave to support it. Once the front two screws are removed, tip the front down, pull the cord out of the upper cabinet. Then lift the back slightly to remove it from the channel on the wall bracket. Set it down Done.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a AEG built-in microwave oven that im trying to uninstall from the cabinet but cant seem to find the means to remove the mounting frame that is fixed to the face of the kitchen cabinet.
1st: Dont listen to the so called gurus at FixYa. As the guru there was telling me that the frame was glued to the cabinet. If I would have followed his recommendation Id be buying new cabinets as well as a new mounting frame. FixYa should credit me my fee paid.
The solution: For the built-in cabinet AEG microwave oven, it is required to use the AEG mounting kit. The AEG mounting face frame uses for screws, one at each corner concealed by small black plastic caps that blend in perfectly with the contour of the mounting face frame. If you look closely towards the inside of each corner you'll see a very small slot in the cap that will allow you to put a small flat head screw driver into the slot to work the cap out. Once the four caps are removed use a phillips screw driver to remove the screws that fix the mounting face frame to the cabinet.
Aug 28, 2009 | AEG Microwave Ovens
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1482 Microwave Oven Logo
19 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
