How To Setup Port Forwarding
I have a new wireless router (Linksys EA6900) and i need to port forward my security DVR
SOURCE: port forwarding? 2wire 2701hg-T
access your gateway homepage by opening your internet browser and typing this on the address bar: 192.168.1.254/management. then key in your system password and click on Settings under Firewall. there's option#2 (allow individual applications), click on "Add a new-user defined application", input the data and click submit another way is to enable DMZ plus mode. that option would actually make all the ports open. use this if option#2 is not working. after making the above changes refresh your router, just unplug then replug it from the power.
Posted on Feb 19, 2008
ohms
  • 1879 Answers
SOURCE: Port Forwarding On Linksys RV016
No change needed on the RV016 - same IP & Port
Check settings on the NEW Workstation (Remote Access grants / Ports assignment)
And your Computer as it is still looking for the old workstation (RDP is more on the computer's identity not the IP address).
Posted on Sep 08, 2008
SOURCE: Port forwarding & Remote Management setup on Linksys WAG200G
here is how you set up port forwarding:
1. log into the router;
2. Click the Applications & Gaming link near the top of the page. 3. You should now see a new menu. Click Single Port Forwarding or Port Range Forwarding.
4, Enter sth like: HTTP; 80; 80; TCP; 192.168.0.1; check
5. When you're finished, click Save Settings near the bottom of the screen to save your changes.
go to administration-> remote administration to set up remote management
Remember, remote Administrator requires you to forward the 4899 ports.
Posted on Mar 24, 2009
InstantFixer
  • 34 Answers
SOURCE: Port Forwarding with Kaspersky Internet Security 2009
Anti Hacker -> Settings -> Enable Firewall -> Low Security -> Settings ->
Rules For Applications -> Add -> Torrent
Edit Rules -> Add -> Rule Name -> utorrent
Properties -> Remote port (selected)
properties -> Local Port (selected)
Rule description -> Remote Port - >(enter the port) -> DEPENDS YOUR CONFIG
Rule description -> Local Port - >(enter the port) -> DEPENDS YOUR CONFIG
Allow Inbound and Outbound TCP connection, where :
Remote Port: DEPENDS YOUR CONFIG
Local Port : DEPENDS YOUR CONFIG
Posted on May 25, 2009
  • 58 Answers
SOURCE: Port forwarding on dlink adsl2 router
Step 1. Before you open ports in your router, set the computer (or the device) which requires
ports to be opened for, with a static IP address. You can choose any IP address from the
range of addresses you are using on your local network, as soon as it is not used by any other
device. The default range is from 10.1.1.2 to 10.1.1.254. In our example we are using
10.1.1.99.
Windows XP: Control Panel > Network Connections > Local Area Connection > Properties >
Internet protocol TCP/IP > Properties
Windows Vista: Control Panel > Network and Internet > [Network and Sharing Centre] > View
Network Status and Tasks > View Status > Properties > Internet Protocol v4 > Properties
Select the “Use the following IP address” option:
IP address: 10.1.1.99
Subnet mask: 255.0.0.0
Default Gateway: 10.1.1.1 (your router’s address)
DNS: 10.1.1.1 and 61.88.88.88 (or whichever your provider is using)
Now open the necessary ports in your router and redirect the traffic to the 10.1.1.99 address.
Here are the steps:
How to open ports in your router Page 2 of 6
Step 2.
Open your web browser and enter the IP address of the router (http://10.1.1.1). Enter
user name and password (default username “admin” and password is “admin”).
Step 3. Click on Advanced at the top and then click on LAN Clients.
How to open ports in your router Page 3 of 6
Step 4
. You will need to add a LAN Client (the address of your computer or a device) into the
router before you can open any ports. Type in the IP address of the Computer/Device (the
one you assigned in Step 1). You can specify the name of this workstation under Host Name
(optional). Click Add and then Apply.
Step 5. Go to Advanced > Virtual Server (Port Forwarding). There is a list of pre-set ports in
the router which you can choose from.
How to open ports in your router Page 4 of 6
Step 5a.
If your specific application is not listed there, you can add the necessary ports
yourself. Select the “User” Category and click on Add button below.
Step 5b. Enter a name for this entry under Rule Name. Then select the necessary protocol. If
there is a range of ports to open, specify the starting port under Port Start and the ending port
under Port End. If you need to open just one port, specify this port number in all fields
including the Port Map. Click Apply.
How to open ports in your router Page 5 of 6
Step 6.
Go back to Advanced > Virtual Server. Under LAN IP select your LAN Client (which
you added in Step 4). Select the Category and the desired Rule or select “User” Category
and you should see the rule which you have created in Step 5b. Select it and then click on
Add > to move it into the Applied Rules section. Click Apply.
Step 7. To save the new settings into the router's memory go to Tools > System. Click on
Save and Reboot button. The router will save the settings and restart.
Posted on Jun 21, 2009
Linksys port forwarding
This WEB site shows how to port forward.
http://www.wikihow.com/Port-Forward/Open-Ports-on-a-Linksys-Router
May 05, 2013 | D-Link DSL-G604T Wireless Router
Westell 7500 set up guide
modems are not routers. Routers can port forward. You need your WAN to face your ISP, and your LAN will need to face your router. Once you have your router talking to your ISP you can set it up to hand out interal network services, but I doubt SOHO routers will do port forwarding. Routers, however, can do port translation like passing gaming traffic over port 80 (web). You can do that in the security tab on your linksys.
Jan 13, 2013 | Westell Wirespeed Westell 7500 Dsl Modem...
Where do i find the port forwarding?
To access the Port Forwarding option of your router, you will need to access the router setup page and from there you will find Application and Gaming tab and there you will see the sub tab port forwarding that is where you can open the port that you need to work behind the router.
Aug 12, 2011 | Linksys WRT54G2 Wireless Router
BL-C131 port forwarding.
So you've configured port forwarding on the router. Do you have any anti-virus applications installed or have your set an exclusion in Windows firewall?
Feb 01, 2010 | Panasonic BL-C131 Network Camera
Nat settings on a linksys wireless router
NAT Configuration is also called Port Forwarding. You can simply open the ports by going to the router's setup page http://192.168.1.1 no username and password is admin. You can do it under Applications and Gaming tab, Port Range Forwarding.
Jun 20, 2009 | Linksys Wireless-G Broadband Router
Mar 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I nd to configure dynamic host for my dvr camera through router
You need to assign static IP on your dvr camera, then open the port(port forwarding) for your camera using the router's setup page.
Jan 18, 2009 | Linksys Wireless-G WRT54G Router
Port forwarding my wireless interent linksys and netgear
access the admin page by http://192.168.0.1 - If you have the manuals, you should be able to access port forwarding with the admin page.
Manuals are avail. online, as well.
May I ask, what do u need to setup for port forwarding?
Oct 24, 2008 | Computers & Internet
Port forwarding
Go to the routers setup page labeled port range forwarding, and type in the necessary information in order for your item to work.
Apr 13, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
