Sherwood rvd6090rds When start the digital 5.1 function,moving the volume control,up and down the signal of all speakers.
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: My Sherwood RD-6105 shuts off
It's acting as if a short or near-short exists on the amp outputs at medium levels.
Disconnect one of your speakers at a time and try it. Make sure your speaker wires are tight and not shorting to anything and all channels have 6-ohms or more load.
Posted on Jan 16, 2011
Testimonial: "When I first Googled this, a few sites popped up offering to fix my proplem, but they wanted a fee (i.e. $48, $34, or $12). FixYa is FREE!"
Sherwood CDC-5506 5-Disc CD Player - does it need Amp ?
Yes you need and amp Look at the disc player there is no volume control or speaker outputs.
Nov 21, 2013 | Audio Players & Recorders
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
I have a Sherwood Nottingham R-925RDS receiver. No matter what input I select it does not connect to the amplifier section. Everything else appears to function ok. Unit switches on & off, correct...
Let's work with FM as that is ONboard and can't be connected wrong. Does THAT work?
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 06, 2011 | Sherwood Audio Players & Recorders
I have a sherwood RX 4109.....can i hook a pair of 6 ohm speakers and then a powered sub?
By design, yes for one pair of 6-ohm speakers used at a time; depends on the sub for the second BUT there is no way to control its volume at the Sherwood.
Mar 25, 2011 | Sherwood RX-4109
I have an rd 7103. Just moved. Hooked up again and no sound. Reconnected every wire several times and no sound even through the headset. all functions on the remote work even the aux outlet ?????
Mar 21, 2011 | Sherwood RD-7103 Receiver
My Sherwood RD-6105 shuts off if I turn it up past 28 or 29 db (which isn't very loud). I'm using it in Dolby Digital mode. It even happens when I use it with my components that are analog. This just...
Jan 16, 2011 | Sherwood RD-6105 Receiver
Would like to hook up two recievers to push all my speakers comfortably. I have a pioneer vsx d490 and a sherwood rd 6500. How wud i accomplish this?
I think you mean Pioneer VSX-D409.
Since the two receivers are similar and capable of driving everything else in the room, I guess you want to treat one receiver like a basic amp, like for a passive subwoofer, right?
However, still guessing your intent...
The VSX is a basic 5-channel amp (5 x 100w) but only has digital multichannel inputs. It has optical and coaxial digital inputs and an optical digital output.
The Sherwood has coaxial and optical digital inputs and no digital output, but it has analog inputs, so it would be easier to selectively use any or all of its amplifiers, which are about the same as the Pioneer's (gotta read the fine print - Sherwood uses a 6-ohm load instead of 8-ohm to get the numbers).
Choose the one you like to use for the control (master). Run its Sub Out to the other receiver's AUX input using an RCA splitter to feed both input channels. Attach the sub to one set of front speaker terminals. Configure theat receiver for NO SUB so it won't steal LFE from theis channel. Designate the FRONT speakers as Large.
Setup would be tricky because you have to choose a volume setting on the slave amp and stick with it. It might get changed after you set the levels and negate the setup efforts. OTOH, you would have the flexibility to change it independently if desired.
My $.02... If subwoofer power is all you need, why not just get a nice Carver 2-channel amp on eBay (2x100w would suffice), bridge it to 200 watts and blow the house up, figuratively? Then you could redeploy or sell the unused receiver.
Jan 18, 2010 | Sherwood RD-6500 Receiver
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
 Grubhead
Grubhead
