Question about Toshiba Tablet. Excite 10.1 in. Android 3.2 Honeycomb 1GB Tablet
Why does my toshiba at300se has been charging for 14 hours. Is at only 33%. Why is so slow?
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
How to unfreeze a toshiba at300 ?
Hold the power button down. Being that it is frozen may take a little longer than usual, but less than 30 seconds.
Sep 16, 2014 | Toshiba AT300SE-101 10.1" 16 GB Wi-Fi...
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
Jul 01, 2014 | Samsung Galaxy Note 10.1"
Kindle fire hd tablet won't charge up
1) Plug it into a different USB port on your pc;
2) Use a different USB charger - look to see if the one supplied with your 'phone has the common Micro USB jack;
Fire's take about 14-16 hours to charge from a pc and 3-5 from the wall,
Jan 27, 2014 | Amazon Kindle Fire HD
Tablet slow to charge, won't hold charge
Hi Michelle Y, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
what is the make and OS it is running..and how long have u been having issuses..like it just started or has it been acting up over some time..
Ill follow this
Chadman
Dec 27, 2013 | Tablets & eReaders
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Transformer Book T100
Battery charges super slow, battery doesnt last long neither. Should of got a Surface?
A HDX should charge from the wall in about 3-4 hours.
IF you are charging it off a USB connection on a pc or laptop the charge time could be 17 hours or never if it's an old or rubbish pc or laptop.
This is true for ANY device you are using, regardless of it being Amazon, Google, Windows or any other system.
Tablets can last up to about 12 hours if you are passively reading a book on it with everything else turned off.
They will run to empty in about an hour if you are playing a fun app that eats screen and memory.
Perhaps reconsider what you want and what you want to do with your product before blaming the technology.
Dec 17, 2013 | Amazon Kindle Fire HDX 8.9
It wont turn on
When a tablet is completely dead you will need to charge it from a wall plug and not a computer. Also try holding the power button for 20 seconds, it is possibly frozen.
Feb 01, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
Battery fails to charge completely
It sounds to me as if your battery is faulty. No way should it take 17 hours to charge. The battery is abviously not absorbing the charge and this could be because one or more cells are defunct. You can just wait until it fails completely or look at getting a replacement before this happens.
Please remember to rate this solution.
Nov 02, 2008 | Gateway CX200S Tablet PC
Toshiba Tablet. Excite 10.1 in. Android 3.2 Honeycomb 1GB Tablet Logo
158 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
