Question about Perfecto Manufacturing Single Bright Strip Incandescent Aquarium Light in Black Size: 15 W
Why is my perfecto light flashing on and off? How do I fix this problem?
It is a 91N1 model 30" RFH-F 120 volt 60 Hz 20 watts light.
I have steamvac 120 V 60 HZ 7.9 A im going to use in my country Argentina 220 V 50 HZ input i need a tranfo 220V 110 V and who many watts?????
220 volts at 7.39 amps = 1738 watts
120 volts at 7.9amps = 948 watts so any unit capable of 1000 watts at the 110 volts will do the trick
Jul 11, 2017 | Audio Players & Recorders
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
I have an old zenith is4070. I am trying to figure out how many watts it pushes out to my speakers.
Model # IS 4070
AM/FM Stereo Receiver
With Phonograph and Cassette Play/Record
Serial # W288209
Power Source AC 120 V 60 Hz
78 Watts 0.65 Amps
Unswitched
AC 120V 60 Hz
200 W Max
Jul 09, 2011 | Zenith Audio Players & Recorders
I have a trailer house that has a 100 amp breaker box in it. I has gas for heat, water heater and stove. I am changing them to electric. Will I need to change the panel put to a 200 amp.
Its probably not a bad idea. Thats alot for a 100A panel to handle, a range needs a 50A, a water heater needs 30A, and the heat will need a 50A or a 60A breaker... Plus whatever else is in the house will be a bit more than the 100A service can handle. But if you don't have the money it will do for a while because for the most part they won't all be pulling at the same time. Word to the wise get at least a 30 space panel when you upgrade, I always install a 40 space panel because for the cost difference its well worth it for future needs because you'll fill it up quicker than you think and you'll have space for anything else you may want to add later on. Hope I helped
Dec 09, 2010 | Your One Source Homeline Circuit Breaker
I need a phone # or an address to order a manuel for a black and decker all in one breadmaker model#catB1550 type1 600 watt 120 volts 60 hz
Customer service information: Please contact with comments, questions or concerns at 1,800,231,9786 (Monday - Friday 8:30 AM - 8:00 PM ET
Aug 25, 2010 | Microwave Ovens
Misplaced power supply. Need to know output voltage.
Power Device Power supply Voltage Required AC 120/230 V ( 50/60 Hz ) Power Consumption Operational 36 Watt AC 120/230 V ( 50/60 Hz ) 36 Watt
http://www.ciao.co.uk/Productinformation/Iomega_NAS_100d_160GB__7879311
Aug 10, 2010 | Iomega NAS 100d/160GB
My model # is 417.89875100 - i need to know the voltage it uses! 120? 220?
A 120-volt, 60-Hz., AC-only, 15- or 20-amp, fused electrical
supply is required
Here is a link for your owner's manual
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0409319.pdf
Feb 04, 2010 | Kenmore Washing Machines
How can i use Sony 5.1 Receiver STR-DG520 in India (120V to 230V)
Sorry, but according to Sony this set operates only on 120 volts at 60 hertz. As we have no real need for up converters here in the USA, I cannot recommend one for your application. The best course would be for you to visit one of your local electronics stores and provide them with the specific current requirements. I'm certain that an appropriate converter is available in your area.
Bill
Aug 21, 2009 | Sony STR-DG520 Receiver
Perfecto Manufacturing Single Bright Strip Incandescent Aquarium Light in Black Size: 15 W Logo
87 people viewed this question
Top Perfecto Manufacturing Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Perfecto Manufacturing Fish Expert? Answer questions, earn points and help others
