Question about General Electric PFSS2MIYSS Bottom Freezer Freestanding Refrigerator
Stop buzzing noise ge pfss22miyss - General Electric PFSS2MIYSS Bottom Freezer Freestanding Refrigerator
GE Side-by-Side Refrigerator GSE25GGHBCWW has a buzzing noise if any food touches the plastic shield over the fan in the freezer section.
Try taking off the fan cover and see if the blade has slid too far forward on the motor shaft. If that's the case just push it back a bit to give it more clearance( do this with the fridge unplugged)).. It could also be ice buildup which is then hit by the blade at the slightest pressure..
Jul 12, 2017 | GE Refrigerators
GE microwave has power, does heat and no buzzing noise
Likely one of the microswitch door interlocks is bad. Happens to many microwave ovens.
Sep 03, 2014 | GE Microwave Ovens
Buzz noise behind dashboard 2001 GS300 LEXUS
The buzz noise is probably coming from the airflow controls turned off but being stuck in a particular mode such as vents and feet mode or winshield and feet mode, creating a buzzing noise while it is turned off. To stop the buzzing noise turn off the aircondition / heat by pressing the off button, next press the mode button for the fan controls to make the picture point to face only not feet or winshield, this should stop the noise.
Oct 01, 2010 | 2001 Lexus Gs 300
My 19 inch ge tv makes buzzing noise can it be
I've had this happen on a couple of TVs, it's always been from moisture getting into the back of the TV. I've been told by a few techs that the issue is beyond economical repair on older televisions.
Mar 14, 2009 | GE Televison & Video
Microwave not working
faulty relay or solder joint on the power module, but a bad door switch is most common.
Nov 13, 2008 | GE JE1860 Microwave Oven
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
Refrigerator Buzzing
if my guess is correct, that buzzing sound could be coming from the evaporator fan touching the ice that builds up in the evaporator. if that is true, a quick remedy for the noise to disappear is to thaw the ice, unplugged it for a while but as ice builds up again, then the noise would come back. the original problem would be the defrost cycle not functioning well. will be in touch if my guess is correct. thanxs,
Feb 11, 2008 | Refrigerators
Buzzing noise, wont work???
The magnatron is shorting, overloading the high voltage transformer. From the picture this looks like an older unit and is probably not worth a magnatron replacement.
Dec 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric PFSS2MIYSS Bottom Freezer Freestanding Refrigerator Logo
27 people viewed this question
Top General Electric Refrigerators Experts
Dan Webster
Dan Webster
Darrell
Day Coker
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
