I need a main board JUG7.820.922-1.
Used in plasma tv CROWN Model APLASMA 4210.
  • 3 Answers
SOURCE: plasma tv techwood 4210
hi the most common fault on this tv is what you describe .i fixed mine by replacing the capacitor (1uf 630vdc) at location c19 on the power board .. cost for this component less than 90p
Posted on Mar 16, 2008
SOURCE: AKAI Plasma TV PDP5016H
I still haven't got my TV fixed, the board that you sent me didn't help at all it has the same problem with the new board just like the old one, I still need help if someone can help.
Thank you
Posted on Oct 09, 2008
jerryg50
  • 1689 Answers
SOURCE: I HAVE PLASMA TV MYRICA P50-2.
The link below is where you can get the information about how to buy Fujitsu television parts. I have no idea if they will sell to non contracted servicers. These sets are serviced mainly by board swapping. You can eaily buy boards that you think are defective, and they are not the fault. This is the gamble you will be taking when servicing these sets yourself.
http://www.fujitsu-general.com/global/contact/pdp.html
Jerry G.
Posted on Jan 31, 2009
  • 53 Answers
SOURCE: how many Main Boards are in the Philips 50
the Philips 50'' Plasma TV model 50pfp5332D/37
has only one main board
has many sub bords supporting tat main board
Posted on Mar 08, 2009
SOURCE: PDP5016H Akai Plasma TV
is the control board the one with the rca jacks on it,for sound and video input?if so email me at mesa1965@yahoo.com,i need one.
Posted on Dec 06, 2009
Hi, I have a Sansui SV-4210 LCD HDMI TV . It does not switch on with the remote and only works once I unplugged the power cable and plug it back again. Lately it occurs every time and I have to do th
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 20, 2014 | Sansui Televison & Video
Plasma TV with blue people
Depending on model it is likely the main board that processes all information in the set to the screen unit.
Google the model number with "parts" to locate a source with a list of the boards used---might want to try "shopjimmy.com".
Jun 08, 2012 | Hitachi Televison & Video
Hitachi 55" plasma TV. 5 years plus old, used a
Please let me know whats the model number of the tv so that I can tell you what the PCB LED diagnostics are pointing to. It sounds like a power supply or Main board issue so I would like to confirm which one of them it is.
Dec 22, 2011 | Hitachi 55HDS69 55 in. Plasma Television
My TV screen turns green with no picture until i turn it on and off TV is approx. 2.5 yrs old and is used very little and it seems to be getting worse thanks Kent
This tv a CRT tube tv?Or a LCD tv or a Plasma tv?The tube tv,the video board that connect to the CRT tube head have problems.The Plasma or a LCD tvs.The main board,call the Tuner board is the cause,this board,that where the incomming broascating signal cable plug into it.CRT tube tv,old technology,must take to tv shop for estimate and repair.Plasma or LCD tvs can tries websites like Shopjimmy.com or Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 19, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
Oct 28, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Akai PDP4247-L PLASMA main power supply module
Yes there two power supply unit one for the main power supply is used for the plasma screen which helps to display the image on the tv screen ,So you need to replace the main power board did they say they have it??
Sep 08, 2008 | Televison & Video
Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Plasma tv techwood 4210
Oct 11, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
