Question about Jeep 2002 Grand Cherokee LAREDO
02 jeep Grand Cherokee, Fan racing when idle, Temp gauge runs to max but no engine over temp
When driving Temp gauge and fan normal, when Idle temp gauge spikes and hear fan racing but engine not overheating..
    Sergeant:
  • 291 Answers
How are your fluid levels? fan speed goes up because of the spike in temp you have,, you are supposed to change your antifreeze yearly.. I suggest having your Jeep serviced by a qualified shop.
Posted on Jan 02, 2015
2 Suggested Answers
harrigilljoe
SOURCE: Hesitation accelerating and rough idle in 2004 Jeep Grand Cherokee
Sounds like a vacuum leak.
Posted on May 13, 2012
Testimonial: "Thanks for the suggestion. I'm going to give that a try."
How do i test coolant temp sensor
This is normally the fan relay which is fried. It can be that the fan is pulling too much current , which causes the relay to fry. It is a good thing to change both fan and relay.
If the sensor is faulty, then you won t see coolant temperature on the instrument panel.
Apr 27, 2013 | 2003 Jeep Grand Cherokee
I have a 2001 jeep grand cherokee with a 4.7 and I just changed the thermostat in it because the housing was cracked now the engine will heat up to around 200 deg or so then the fan will kick on and the...
Those motors run HOT. if your not losing any coolant and your system has a fairly recent i.e. in the last two years been flushed I wouldnt worry about it.
Sep 14, 2011 | 2001 Jeep Grand Cherokee
2002 jeep gr. cherokee laredo overheats only when sitting at an idle, temp comes back down when heater and fan are turned on full blast as long as jeep is moving
you electric fan probably isnt working with vehicle warmed up lift hood and watch temperature gauge when it starts to over heat check to see that fan is working if not it could be the fan relay or fan itself if the fan does turn on its most likley the thermostat
Aug 11, 2010 | 2002 Jeep Grand Cherokee
My 2004 High Performance Jeep Grand Cherokee Overland all of a sudden when idling, the motor begins to race and the temp gauge goes over to 260. When you put in gear and drive it goes back down quickly. It...
Is it really the engine which starts running, or is it the hydraulic cooling fan which makes a lot of noise due to the high coolant temperature? Since the temperature drops down rapidly when you start driving, the problem seems to be with a restricted airflow from the cooling fan. Was the radiator changed lately?
Take care in not overheating this engine, because the heads can warp (coolant leak) and/or it can start dropping a valve seat.
Nov 18, 2017 | 2004 Jeep Grand Cherokee
I have 2003 grand cherokee with 140000 miles that overheats at idle. as soon as i start moving again, the temp goes back to normal.
You have two fan's on your truck, 1 is a fan clutch runs with the drive belt, 2 elec fan motor, with test light and engine running at normal temp, just a little bit above 1/2 way on your temp gauge check voltage at elec. cooling fan harness if you have voltage at one of the two wire's and fan don't turn on, bad cooling fan motor, on the fan clutch after you check voltage at elec. fan motor turn engine off, with your hand spin drive belt fan if it spin's freely bad fan clutch, replace it.Also check cooling level.Hope this was very helpful
Jan 21, 2010 | 2006 Jeep Commander
Temp increases on idle and aircon fails
Does the electric fan come on and stay on when it's hot? Find what's clicking it could be the relay for either a/c or fan. (though they usually are on the passenger side in the power distribution center near the battery. Your system works pretty much like this: the temperature sender on the engine sends info to the computer which sends a message to the relay to turn the fan on. The a/c bypasses this to some extent and turns the fan on every time the compressor is running.
Your radiator must be really clean or it would be blowing coolant all over the place a bit over 210, unless the gauge is reading incorrectly.
May 23, 2009 | 1995 Jeep Grand Cherokee
No/low oil pressure, high engine temp
I think you have a bad ground on your engine gages...but, more importantly, have your oil pressure checked by a mechanic.  If it is indeed only 20 pounds the engine is sadly on it's last legs.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Apr 28, 2009 | 2002 Jeep Grand Cherokee
Temp gauge goes to full hot while at Idle
Check the auxiliary cooling fan for operation. As the engine temp rises, it should kick on to bring the temp down. U may have a bad motor on the fan, or more likely a bad fan switch.
Dec 22, 2008 | 2001 Jeep Grand Cherokee
99 cherokee laredo over heating
You can test the system by disconnecting the engine temp sensor that turns on the fan, the engine computer will go into failure mode and turn on the cooling fan, if the fan does not run check for voltage at the fan with a 12 volt test lite..
Sep 08, 2008 | 1999 Jeep Grand Cherokee
Jeep 2002 Grand Cherokee LAREDO Logo
183 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
