Question about Pasquini Livia 90 Espresso Machine
Replace steam knob - Pasquini Livia 90 Espresso Machine
Cant turn the steam knob
Replace the steam valve. It is not very hard to do and you can find a new valve with a Google search.
It is possible to attempt a repair but it is as hard to just replace the valve and repaired valve usually leak a bit.
Dec 28, 2012 | Rancilio Silvia Espresso Machine
Gaggia classic steam knob
Have you turned the steam valve off tightly and cracked the knob inside allowing it to turn on the brass spindle.Try pulling the knob off and turning the spindle with a pair of pliers or a small adjustable spanner.If the spindle keeps turning you may have sheared the spindle off inside.If this is the case you will need a new steam valve complete as they are not repairable.Steam valve cost about 35
Tools required 5 mm alan key and 17 mm spanner for steam pipe
Jun 16, 2012 | Gaggia Classic Espresso Machine
My francis Francis X1 constantly drips water from the steam wand. i've decalcified and decalcified. Any help??
The problem is with the two O ring which are on the steam knob srew. So you need to disasemble the steam knob srew by turning it all the way reverse. On the srew axis you will find two O rings which must replace. You can fint easy replacements O ring from DIY shop they usuly have O ring kits with diferent sizes so take one with youto match it with that of the shop.
Feb 22, 2012 | FrancisFrancis! X1 - Stainless Steel...
How to replace the steam knob from the DeLonghi Magnifica? Here pic with broken button: http://s3.imgimg.de/uploads/delonghi7e8dacc0jpg.jpg
I have had the same problem and the repair will not be onerous. You can buy a new steam knob on coffeemaker website (here the link for a new steam knob) but also on a lot of other web sites.
Don't forget to grease the screw that holds the steam knob. I have used some vaseline to mahe the replacement easier.
Aug 21, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
1. Where is the lever located in the Saeco Incanto De Luxe located? 2. How do you decalcify the same same product? Thank you for your help
Hello Dolls36,
I understand you have two questions the lever question I assume you are taking about the steam lever. The second question is how do you descale the unit.
Lets answer the first question first. The steam lever is not a lever but a knob. The knob is located on the right side of the unit.
1. Put container under steam tube turn knob downward to open until you get steam
2. Once you get steam turn knob upward to close
3. Put item you want to steam under steam tube and open valve back up to steam
Now to answer the question about how to descale the Incanto De Leluxe. When you are ready to descale the machine follow these steps.
1. Hold down the "x" button for 5 seconds, the machine will tell you it is ready to descale
2. Remove the filter
3. Fill the water tank with your descaling solution
4. Insert a container under the steam tube and open the steam valve
5. The machine will display descaling and finished
6. Then it will prompt you to fill tank with clean water for rinsing.
7. Press the "x" button once tank is full
8. Place container under steam tub and turn knob to open steam tube
9. When finished press "x" button one more time to confirm done
10. Replace water filter and fill tank
I hope that I have answer you question as for question 1 I assumed that is what you were asking about. However, if that was not the right question please post back to this tread and I will be more than happy to answer the question that you specify.
Thank you for choosing FixYa.com
Justin
Mar 11, 2011 | Saeco INCANTO DELUXE Espresso Machine
Steam knob keeps turning around-and no steam
Sounds like you have a striped knob and your valve is frozen. You will have to replace your steam manifold and valve.
Sep 21, 2010 | Solis Crema SL-70 Espresso Machine
My francisfrancis 24fa expresso maker short circuited and sparks came out. how do I open it up to dry it out and how hard is it to get replacement parts?
Hi
Unplug the machine!
First remove the steam knob. hole below the steam knob. Straight blade screw driver. loosen the screw about 2 turns and the steam knob will unscrew.
next remove the 2 screws on the front.
Next remove the 4 screws on the under sides of the machine.
The top will slide back and off.
Dec 29, 2009 | FrancisFrancis! Coffee Makers & Espresso...
Gaggia syncrony compact is leaking. Removed top and it appears it is leaking from the area that the line goes into the steam knob. Doesn't leak when using the steam knob, just when brew coffee
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Jun 14, 2009 | Gaggia Syncrony Compact Coffee...
Cafe verona delonghi
You need to turn the knob on top to the steam logo. then turn the knob on the side to open the steam valve. then when you get all the steam you need turn the knob back to brewing
Sep 11, 2007 | DeLonghi Caffe Nabucco BCO70...
Pasquini Livia 90 Espresso Machine Logo
22 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
De Brewerz
De Brewerz
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
