Question about KEF Audio HTB2 Subwoofer
How do you open the kef htb2 sub - KEF Audio HTB2 Subwoofer
Subwoofer cuts out kef (2010)
a capacitor could be overheating and cutting out.then,when it cools you get sound again.this will go on and on until you take it to a tech to get fixed
Aug 04, 2013 | KEF Audio Audio Players & Recorders
How do I open up a Kef egg speaker
9aa4f771-e31b-4b6e-a152-d7f1795ba2f6.jpgRemove the rubber ring around the speaker, by pull gently outwards. then remove the speakers or resonator. if necessary remove the other side as well
Jan 26, 2012 | KEF Audio HTB2 Subwoofer
Only One Subwoofer output is on my Denon 2309, but KEF Sub has two In L+R, which one should I use or do I have use Y Split Sub Cable
KEF manuals are really hard to find especially when we don't know ahat model it is. Do you have YOURS? The split-Y is guaranteed to work.
Sep 04, 2011 | Audio Players & Recorders
When my KEF home theatre subwoofer is maxing out on bass, it often makes a loud popping noise. Should I be making some adjustments to reverb, volume, or something else?
Yes you should make adjustments.KEF makes very good products, however if you don't handle this you will have to replace or service it.
1 If the woofer is very close to you, relocate it further away. The reason being is that the lower the frequency the larger the wave form. The lowest waveforms will become louder.
2 Adjust the high frequency cut off to be at 80Hz. This should eliminate boom. Higher Sub frequency tend to muddy the sound.
3 The sub should have a subtle effect in music. So the relationship between it and the speakers it augments the sound of should be seamless.
4 If you are playing Rap or Reggie music and you like to play it loud. Add another sub into the system and locate it NEXT TO the KEF Sub. In this fashion the two subs will reinforce each other's energy. They will "couple" thus multiplying their energy considerably.
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Audio Players & Recorders
Im having trouble with connections from kef psw 1000 sub to onkyo tx sr506 amp. sub is making a bit of a humming noise but not getting any proper sound through. dont know what im doing wrong. can anyone...
Have you got the sub defined to the Onkyo correctly? Try conencting the sub's input to one of the Tape Out connectors and play some FM through it. That will prove if the sub is alive. The nwe can troubleshoot the correct failing device.
May 03, 2010 | KEF Audio PSW 1000 Subwoofer
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
I thinking of bying this Sub, but I have an old Yamaha RX-V660 receiver. Can I conect the Sub to that receiver and how?
Not very easily. Your receiver has no Sub Output. You really want a sub that supports hi-level inputs such as this: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-633
Then you can run your front speakers through the sub.
The Kef site hints it may be possible to run high-level inputs to that sub by using RCA adapters.
Aug 27, 2009 | KEF Audio PSW 1000 Subwoofer
KEF KHT 2005.2 SUBWOOFER
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25.
Dec 06, 2008 | KEF Audio KHT 2005.2 System
Kef kit 100 buzzing popping
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25. I would have all 6 replaced. It is better to run a matched set.
Sep 05, 2008 | KEF Audio KIT100 System
KEF Audio HTB2 Subwoofer Logo
70 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Greg Cann
Greg Cann
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
