Question about Dryers
My dryer, model Mdg6800aww, currently vents to the side but I need to change it to the back but the installation and user manuals do not say how to do it. Any ideas?
    Scholar:
    New Friend:
  • 81 Answers
You need to take the dryer apart to do that. You would have to reroute the vent internally to go to the back of the dryer. http://parts.sears.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDG6800AWW/3048/0151200/W0703640/00001
It's piece number 17. You have to get started by taking the screws out of the left and right side of the door hinge. Then open the door and pull the front panel forward. There are two 5/16 on the bottom of this model you'll have to remove, I'm pretty sure, too.
Posted on Nov 27, 2013
SOURCE: Vent Kenmore HE2 dryer from the Side, not the back
I'm in the same boat as you. Just had my dryer delivered today. Did you find a solution?
Posted on Jan 11, 2008
aborcass
  • 2651 Answers
SOURCE: How to Side Vent a Duet GEW9250 dryer?
you dont need a kit, get under ther with an elbow and some solid vent tubes, a little foil tape and your in, should be a prefforated knock-out where it will vent through side,
Posted on Feb 22, 2008
barkencoa
  • 3463 Answers
SOURCE: Change dryer vent from side to rear
Not all dryers have the facility to vent out of the side, if they can , you should see a knockout panel or cover at the side, remove this and fit vent to side.
It is important that you blank off the outlet where the hose was fitted originally.
Plz rate my answer.
Thanks..
Posted on Jan 20, 2009
scottowa
  • 87 Answers
SOURCE: Dryer vent from the back to the side
There is a kit that you will need and it comes with instructions. You need the model of the dryer and you can find it at
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Enter the model number of your dryer and look for it in the diagram. You should be able to go where you bought it also. Good luck.
Posted on Mar 22, 2009
SOURCE: need to find a samsung manual for model dv448aew
Installation manual comes with Samsung Side Vent Kit. Side Vent Kit part # is DV-1A. You can find it from following website link.
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=DV-1A&search%5Fmodel=
Posted on Jan 26, 2010
Dryer not hating up after changing heat sensor
Check this site out------http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-630749-/Maytag-Dryer-doesn-t-heat-MDG6800AWW-------------
Oct 09, 2014 | Maytag Dryers
Maytag neptune #mdg6800aww burner lights but wont stay lit after about 15 seconds
Well that could be a blocked vent causing over heat, bad blower wheel, simply cleaning out the dryer and opening up the vent helps a bunch. Ya gotta take the door off first to get in the machine. Then the front comes off then you can check the innards for airflow issues.
this un is electric model but they come apart the same. If the glowbar comes on and the flame sensor shuts down the glowbar ok and flame comes on and runs about 30 seconds that seems to be the norm for this style dryer. The heat does not stay on. Clean it up and put it back together and if it does better ok if it dont then you gonna need to replace the cont stat and gas valve coils.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 30, 2014 | Dryers
My Maytag Neptune gas dryer has stopped heating The button pannels turn on, dryer spins but no heat I cleaned the vents Model no. MDG6800AWW How do I fix it? Can I repair it myself? Is there a...
When the dryer wont heat it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help...
Dec 30, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Where is the thermal cupple on the maytag neptune GAS DRYER MODEL#mdg6800aww
It sounds like the unit is cycling on the thermal limiter. To verify, disconnect the vent from the back of the unit, if this improves and you have longer cycles, then its more than likely just a dirty vent, However, If you disconnect it and it still continues to short cycle then its the hi limit thermostat & it needs to be replaced
May 05, 2009 | Dryers
Want to vent the dryer out of the right side not the back.
take the back off. knock out the piece you want and move the exhaustr hose connector to the new hole
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
Mar 22, 2009 | Dryers
Need to replace existing back vent to side vent. Is there a kit
From underneath the machine you can install a side venting kit. It can be vented to either side on electric models. Part number is 3911EZ913X. You can order parts by calling LG at 888-393-6484. Hope this helps.
Jan 07, 2009 | LG DLE5977 Electric Dryer
41780042990 Kemore electric dryer
you would need to "punch out the metal" , youl also need to remove the fron tof the unit(2 screws approx 3-4 inches down form inner panel, holding front panel on, ( youll need to remove the top of the dryer( a few screws across the back of unit.) andthen disconnect the dryer belt(easiest acess through a small acess panel on lower rear of unit, pull the dryer drum out and youl see the existing ve, just a matter of attaching a 90degree elbow and running vent out the side instead of out the back. DISCONNECT POWER TO UNIT FIRST!!!!!!!!!!
Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
Maytag Performa dryer venting
You are always better off using steel on these kinds of conversions and do not worry about how hot it gets,..Aluminum will get hot too. Steel is more rigid and less likely to dimple in while installing or hooking up the external vent system... Hope this helps..
Sep 01, 2008 | Dryers
Dryers Logo
42 people viewed this question
Top Dryers Experts
