Question about HP LaserJet 8150dn Printer
Printer makes nail marks in the paper
Hi my printer functions pretty well, the only problem is that the printed paper that gets out of the printer, has little marks, these marks are like a finger nail mark,like if you push the paper with the finger nail, what it could be?, the technician tolds me that its necesary to change the fussion unit, but it is so expensive, does anynoe have another solution?.
  • jefemax Oct 10, 2007
    Hi the printer is an hp 8150dn model
  • jefemax Oct 14, 2007
    Yeah you are right, it seems to be the metal roller in the fussion unit, I took a look inside the printer and i can  see little white marks in the metal roller, like acumulated fine white dust, I'm not sure if I should remove this dust fror the roller, so i think it could be better if i try to replace the roller, is it secure for the fussion unit to replace that only part?
    thank you for the response
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
NO, if you open up the fuser section the fuser rollers are probably shot. They have to be changed, I usually show my clients what I'm talking about when they need a part. it gives them a better perspective of how bad and what I'm talking about.
If you can live w the copies like that then it's o.k. for now, but they will have to be changed eventually, some models you can change the rollers without the whole unit and can cost you less.
Posted on Oct 11, 2007
  • CheckitRight
    CheckitRight Oct 15, 2007
    Yes, you can replace just the rollers ( some models it's easier and less of a headache to replace the whole unit).
    If I were you I would order the part and install it myself  (the whole unit, assuming you are a little technical) on a scale of 1-10 this is probably a 2-3 to replace. It either has levers to turn and unlock the unit or two screws on each end. take out put the new one and that's it.
SOURCE:
We have a 4250. When printing from our software we get a message that reads "manually feed tray 1" or "click the check mark to print from tray 2". No matter what settings i change i...
This is often caused by software asking for paper that is not loaded in the printer. You can use the paper path test function in the diagnostics menu to ensure that tray 2 is working properly. Also check your driver settings to make sure that the paper size shown in the driver matches what is actually loaded. You need to also check and make sure that the paper type for tray 2 is set for plain paper, otherwise the printer will only print to that tray if you ask for the paper type that is set.
Jul 12, 2011 | HP LaserJet 4250n Printer
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
When i print any photo it can't print error show E3
hi, look at this post maybe can solved your problem not all Error E3 means your printer part damage but maybe somethings inside it that makes the printer look likes paper jam,
Canon MP198 Printer Error E3 is because something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things.
Look at the paper sensor there is must be somethings in it. I found this when my printer Canon MP198 got error E3. I found small part of paper in the sensor that makes sensor not function properly. I just remove the paper and the printer working again.
see also
http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html
Nov 18, 2010 | Canon Office Equipment & Supplies
Hi my omni 3200 printer is not printing. The page
You either have the wrong paper in the machine or it is in backwards. It takes thermal paper. Run your fingernail across the paper and if it makes a mark, that is the side which must be facing up when it goes trough the printer.
Jun 19, 2010 | VeriFone OMNI 3200 (P092-101-10) Printer
Epson T88...won't print..no ink....paper does come out, but blank.
This is a thermal printer so make sure you have thermal paper. Take your finger nail or the end of a pen and rub the paper. It should make a black mark from the heat you generate on it. Also make sure the treated side is up,
Dec 05, 2009 | Epson TM T88 Thermal Printer
No ink comes out on the tag
This is a thermal direct printer so it has no ink per say but uses a heat sensitive paper. You can test the paper by taking your thumb nail and scratching like your keying a car. a fast swipe to make some friction and the heat will leave a blank line on the paper. if it leaves no mark its just plain old paper and wont work. you will need thermal direct paper. also in printing defaults in the driver the darkness may be too low and need to be raised, but check the paper first.
Jul 10, 2009 | Zebra Eltron LP 2824 Thermal Printer
Sharp Electric Cash Register XE-A203. I just put a new paper roll into the register because it was out of paper. The register screen is showing all numbers and transactions but when the paper comes...
Hi whitwall,
Please make sure that you have the right paper roll.
Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
You should be ready to go ahead with sales.
This should solve the problem .
Regards
Gavin.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Canon pixma ip 8500 won't feed paper
I have discovered that my problem was a one inch nail which had at some time been dropped into the paper feed slot. It could not be seen from the outside of the printer and was only discovered when I removed the side trim and top cover. When closely inspecting the nylon roller system that feeds the paper out, I saw a tiny piece of metal that looked out of place. Further probing then loosened the nail back to the paper input area.
My printer is now back in full operating condition after spending a couple of careful hours finding out how to remove the trim.
A well worth while exercise in my case.
Oct 15, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
I cant print,scan & copy
try reinstalling the drivers and/or replacing the cables. Also look for any debris or tiny piece of paper that may be stuck between the rollers..
May 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
HP LaserJet 8150dn Printer Logo
77 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
