Question about Whirlpool Refrigerators
Refrigerator not running
No noise
    Problem Solver:
  • 16 Answers
Check power going to it then check circuit bd controlling power
Posted on Nov 25, 2013
Intremittenly makes a loud fan or compressor noise while running.
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Apr 13, 2011 | LG LFX25960ST Stainless Steel French Door...
Fridge sounds like my air compressor in the garage when it runs. Will run for about 25 minutes making this noise then stop for about 15 minutes. Suspect the compressor is going or low on coolant.
It may be the compressor but I suspect that it is the fan making the noise...
heatman101
Feb 11, 2011 | KitchenAid Refrigerators
Noisy fan running constantly - fan noise caused by ice build up
heatman101
Jan 27, 2011 | Samsung RS2630SH Side by Side Refrigerator
Knocking noise
Sometimes when it's to close to the wall it will make noises try pulling it out a bit.
Apr 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator NOISE
Replace the evaporator fan motor.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Noise at the top, constant
Are you saying you get the noise even when the refrigerator is not cooling? If you get the noise only when the refrigerator "runs", it is the fan as you suggest.
Apr 28, 2009 | Viking Professional VCBB363 Bottom Freezer...
Groaning noise on GE side by side refrigerator
Hello Michael,
Thanks for your question, I hope I can help some. My answer is long winded but full of good info.
The noise could be as the GE guy said refrigerant (gas) noise. If it is refrigerant noise it happens as the liquid refrigerant comes out of the tiny capillary tube and enters the evaporator (cooling) coil in the freezer. Along with the liquid coming through the capillary tube there often are gas pockets. The flow of the liquid and gas pockets into the evaporator coil cause strange sounds. If the noise you are hearing is this refrigerant noise, you should only hear the noise while the compressor is running and then only for a short time (1 to 2 minutes) after the compressor shuts off.
If the noise continues after that I do not think it is a refrigerant noise.
There are times when the compressor will not be running but the fan in the freezer will be running on this model. This is normal and working properly but if the noise is present when the freezer fan is running and the noise stops when the freezer fan stops, the likely cause will be the main board located in a square panel on the rear of the refrigerator above the compressor compartment. I know that sounds crazy but the main board can cause the freezer fan motor to make some really strange noises. Eventually the board will probably fail.
One other test would be for you to listen for the compressor to turn off, then if the noise is present after the compressor turns off, you would next unplug the refrigerator from the receptacle. If the noise continues with the refrigerator unplugged it must be refrigerant noise. If it stops, I am betting on a bad main board.
I tried to locate for you information on a material that Whirlpool and Frigidaire as well as some others use as a noise deaden-er that they wrap around where the capillary tube enters the evaporator. I was not successful in locating anything. I am sorry I could not find it.
supertechks
Please don't forget to rate me
Jan 25, 2008 | Jenn-Air JFC2089HE French Door...
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
Refrigerators Logo
29 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
