Question about Ingersoll Rand Dryers
LPCO Alarm Dryer faulted on LPCO High Temp alarm
3 Suggested Answers
  • 185 Answers
SOURCE: I have a whirlpool stackable
can i have the model number please
Posted on Mar 28, 2008
SOURCE: Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
Posted on Mar 02, 2009
My high temp alarm has been on all day
the warming up will be because the unit is not operational and the door hasn't been opened
call a service technician and check for a failed start/run capacitor for the compressor
the high temp alarm indicates that the food is in danger of spoiling
Sep 06, 2015 | Frigidaire White Frost Free Upright...
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
My frigidaire gallery refrigerator model number DGUS2645LF3 is showing an error code "5b" and nothing inside works.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are in the Sabbath Mode.
The Sabbath Mode is a feature that disables portions of the refrigerator and its controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community.
Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds. The display shows "Sb" while in Sabbath mode.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, for example due to a door left ajar, the alarm will sound intermittently for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
If this does not solve the problem you have a bad control board.
Sep 02, 2014 | Frigidaire Refrigerators
High temp alarm
Good Afternoon Friend,
I see that you have the High Temp alarm going off on your Frigidaire refrigerator. First, you will want to press the Alarm Off button to turn the alarm off. Next, you will want to press and hold the Factory Default button to put the temperatures at 0 degrees for the freezer and 37 degrees for the refrigerator. Wait 24 hours for the temperatures to stabilize. If you are still having trouble with the alarm going off, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 2-3 minutes. When power is restored, you will need to press the alarm off button. If the High temp alarm is still going off, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Refrigerators
High temp alarm goes off in the middle of the night even though temp feels fine
Got the manual? The alarm should be able to be just displayed, with the buzzer muted.
May 16, 2012 | Viking Refrigerators
High temp 20-29 F Frequent high temp alarms
check condensor fan if it has one. if not unit may have sprung a leak some where
Apr 10, 2010 | Freezers
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Clothes not drying
The temperture sensor is at fault. It shuts down before the temperture is hot enough
Feb 02, 2010 | Frigidaire GLGQ2152ES Gas Dryer
Alarm/buzzer going off without shutting off
that could be the engine fault alarm, if its a Mercury that indicates high engine temp, low oil pressure (4stroke) low oil level (2 stroke and 4 stroke) Either way, dont ignore it, it will get expensive. this information is similar for Yamahas as well
Sep 11, 2009 | Boating
A C works intermittantly
As far as the heater damper goes, you will definitely have to get taken care of. Not sure if they are vaccum or cable type on that year. I am going to say that you need your ac recharged. If it is low the compressor will kick in and out. Another possibility is the control panel where the controls are. Good luck
Jul 24, 2009 | 1995 Ford F250
Dryers Logo
147 people viewed this question
Top Ingersoll Rand Dryers Experts
Are you an Ingersoll Rand Dryer Expert? Answer questions, earn points and help others
