Question about Saeco Odea Go
Descaling the machine
Can you force the solution through the coffee delivery spouts or just the steam/water pipe? I also would like to just pass water through this as it often tastes of descaler after it has been done.
  • 1,214 Answers
When you have deccaled the machine just let water through two or three times. Then there should not be any extra taste of the coffee. Good luck Kolbrun
Posted on Nov 23, 2013
SOURCE: Water leakage- V'spresso machine
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
Posted on Mar 10, 2009
SOURCE: saeco wont stop descaling
In service menu there are 2 parameters you should look. First one - descaling - should be on 'done'. The second one is a counter - water used since last descaling - should be on 0.
Posted on Mar 23, 2009
  • 1089 Answers
SOURCE: the red light for descaling won't go off after descaling
The button to push was the steam button and hold for 5 to 10 seconds until the light goes out.
Posted on May 21, 2009
  • 1089 Answers
SOURCE: how do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Posted on Oct 26, 2009
  • 1089 Answers
SOURCE: Saeco Magic Comfort plus: Despite descaling the
Hi
In the menu there is a program below the descaling program that says Reset descale. Enter this program and choose "yes", and make sure that you push the enter button to lock your answer. If you don't it will still be there.
Also go to your water hardness and move it to the #4. This will prevent you from having to replace the boiler sooner than needed. Descale when told to by the machine.
Posted on Jan 09, 2010
Testimonial: "Fast, correct and thorough. The cryptic Manual was less than clear but your instructions were excellent. thank you"
Cannot get steam to come out of my delonghi prima donna XS coffee machine
Could not find why but maybe if you go back over the scaling procedure and steam procedure there might be something you missed.
Please note! If "Energy saving" is active, you may have to wait a few seconds before hot water and steam are delivered.
Steam delivery 1. Make sure the hot water spout is attached correctly (fig. 7). 2. Fill a container with the liquid to be heated/frothed and immerse the spout/cappuccino maker (D5) in the liquid. 3. Press the steam ( ) button. After a few seconds, the steam to heat the liquid comes out of the cappuccino maker and "STEAM" is displayed. 4. When the required temperature is obtained, interrupt steam delivery by pressing the steam ( ) button again. (You should not discharge steam for more than 3 minutes at a time).
http://www.delonghi.com/Global/InstructionManuals/EN/EN-PrimaDonna-ETAM36365M-im.pdf
customer support
Customer Support
Nov 25, 2015 | DeLonghi Coffee Makers & Espresso Machines
How do I fix the water problem?
Could be a block pipe. Can you get water out from the steam spout?
Aug 14, 2014 | Saeco Vienna SuperAutomatica Coffee...
Miele coffee maker water not coming through to brew unit
try cleaning the nozzles using fine wires or tobacco pipe cleaner kit. it look like you have a blockage on your tubing leading to nozzles.
Nov 06, 2013 | Miele Coffee Makers & Espresso Machines
No water is comming out of the water spout, the pump is trying but eventually stops and steam escapes from somewhere under the machine. The water spout is not blocked, as when removed you can blow through...
Hi sounds like a blocked boiler. Remove the water inlet line going into the boiler and use a 3mm drill bit and drill the inlet pipe out. Could also be a faulty hot water solenoid. Dazza REPAIRER
Sep 23, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
We have a brilliant Briel Multipro that we use every day but when we have made a cup of coffee and release the coffee holder, steam and hot water spurts from the head area...It stops after a few seconds...
First, I'm NOT a Briel technician, But if you still have pressure from the removal of the portafilter (or capsule) then the exit or pour spout is clogged. You can soak a standard portafilter in warm water over nite and wash it clean in the morning. Really bad? then soak in urn cleaner and flush thoroughly prior to use. For capsule machines follow the MFR's instructions to properly flush the machine. You may also try to "fool" the machine into making a 'no coffee' shot by reusing old capsules over and over again to try and flush out old coffee from the spout. Otherwise the unit may need servicing to remove the clog as most of these capsule machines do not have serviceable parts. Contact your vendor or MFR directly for service or replacement.
*warning! Try not to stick a pin, nail, or paper clip into spout(s) as this may damage valve or offset the dual pour spout. Most of these machines have double spouts and can be easily pushed out of alignment.
* Final; I've noted that your probably using a portafilter type machine. If you have water or steam dripping from head then there is a leak in your head valve or commonly called the 'Group Valve'. Fortunately this is a serviceable part and can be replaced by your vendor.
PS. Have you tried 'Back Flushing? Use a "BLANK" portafilter basket (the one with no holes) or a back flush rubber stopper (from Cimbali). Add a 1/4 teaspoon of urn cleaner of flush cleaner to portafilter and lock onto group. Run shot till it stops (excess pressure and dose will by-pass the group valve. This will flush old coffee and crud out the by-pass pipe and into drain tray. If nothing happens and the group hums for longer than 20 seconds then your probably got a clogged valve and back flush pipe. All will need disassembly, cleaning and/or replacement. Best to call your Vendor for service.
*Be sure to run the group several times and wash the portafiler to get rid of the urn cleaner.
*Tip; It's a good idea to back flush every hour with with plain water from the shot to just get rid of the coffee grounds stuck to the group shower head and leftover coffee in the group valve. Does not hurt the machine and keeps everything working smoothly.
Aloha, youtube; ukeboy57
Jan 11, 2018 | Briel MultiPro Espresso Maker - Brushed...
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
I have a saeco Talea Giro machine. When I press the button to make coffee, the beans grind but no coffee comes out, but raher the water comes out of the steam spout. What is the solution
Check the screen on the brew unit, it might be blocked. If the brew unit is cleaned and the problem is still happening then the steam valve needs to be rebuilt because the pins are allowing the water pressure to pass through.
Oct 07, 2009 | Saeco Talea Giro Espresso Maker -...
Water Spout Leaks after Brewing Coffee
You have to replace the gasket in your steam valve, if you have a steam valve in plastic i recomend you to replace it with a steam valve in metal.
Best regards
/Mirran
Sep 04, 2008 | Saeco Incanto Classic Espresso Machine
Leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Aug 13, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Saeco Odea Go Logo
95 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
