Question about Neff B1421 Electric Single Oven
Power supply I bought Neff oven B1421N2GB from ebay but there is no power suplly cable, want to know where I can get it and attach it
It doesnt come with a cable it has to have its own 25 amp cable from your consumer unit or previous oven installation.
Posted on Mar 04, 2017
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Change light-bulb
You need to remove the whole oven from its cabinet (after switching off the electricity supply). Removing the doors first; (see http://www.youtube.com/user/Apart4u for videos of this) then remove the facia, which allows you access to the two restraining hooks near the top of the sides of the oven. With these slackened off (screws at the front) and pushed back, the oven can be slid out of its housing - be careful, it's heavy - onto a similar height workbench in front of the oven housing. Removing the wiring hatch (2 screws) and the rear panel (6 screws) gives access to the screw in bulb. Hope this helps :)
Posted on May 17, 2007
  • 44 Answers
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Posted on Mar 19, 2009
  • 228 Answers
SOURCE: Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
Posted on Jul 20, 2009
SOURCE: how to replace knobs on u1661 oven
Just pull them off and replace. Its that simple.
Posted on Oct 26, 2012
I have a new neff built in oven. I turned it off over an hour ago and the fan is still running. Surely this is not right. Any suggestions.
Hello, Sylvia -
Since your Neff oven is new, I hope I am correct in thinking you have the owner's instruction manual for the oven and you already checked there to see if there were any troubleshooting tips regarding the fan still running after turning the over off over an hour prior.
If you do not have the instructions for the new oven, check here:
http://www.neff-home.com/uk/service/manual
Note: You will need to supply the E-Nr number for the oven. If you do not know where to find the E-Nr number, on the web page cited above, click or tap on the link for the rating plate finder.
After checking the owner's instructions for the oven, the next thing I would suggest is contacting Neff Specialist. See the information here:
http://www.neff-home.com/uk/service/support
Talk to a Neff Specialist.
You new Neff oven is most likely still under warranty.
Best wishes.
May 01, 2018 | Neff Ovens
Why does it trip breaker?
There probably is an internal short.
Oct 04, 2015 | Neff Ovens
Hi, Looking for a wiring/electrical diagram for Neff D39F56S0GB Extractor hood. Or could you Kindly point me in the right direction. Thank you
You can find the manual here:
D39F56S0GB/01
and here:
D39F56S0GB/02
It should come with a cable attached which should conform to standard wiring colour codes.
Red/Brown = Live/Feed
Black/Blue = Neutral/Return
Green/Green & Yellow = Earth
If the standard cable has been cut off there is a good chance it was for a reason and you shouldn't try to connect it without knowing how to determine which contact is for which (an electrician/electronics tech will know within seconds what should be connected where.)
Mar 07, 2015 | Neff Ovens
We are having a neff oven U15M62NOGB fitted. The wires in the booklet are earth on the left, live in the middle and neutral on the right. Is this correct as the neutral and live are the other way round on...
Yes, the installation instructions are correct. The wiring from your old oven isn't relevant.
Your query is a little confusing though. The new oven should have a power cable attached to it for connection to the mains supply. This should be on a separate circuit from your sockets and connected to an isolator switch. The wires in the power cable are colour coded to ensure that they are correctly polarised when connecting to the mains supply. I'm assuming you're in the UK as you list a GB model number, therefore, it should have a BROWN wire for LIVE, BLUE for NEUTRAL and GREEN/YELLOW for EARTH.
If your house wiring uses the old red (live) and black (neutral) colour coding, then you just need to ensure that the brown (live) wire from the oven lead is connected where the red wire from the supply is terminated. The blue (neutral) wire should be connected where the black wire is terminated and the green/yellow (earth) wire should be connected where the green wire is terminated.
Internally, the oven probably uses red cable for live and black for neutal, but you really shouldn't need to be doing anything with the internal wiring to install the oven.
You say you are having it fitted. Any competent installer would know (or check) the correct wiring order even if the instructions were missing. If you are installing it yourself, be sure are certain you understand what to do before attempting this and double-check the power for the oven circuit is off before you start.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Neff B1421 Electric Single Oven
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
Apr 15, 2009 | Neff B1421 Electric Single Oven
How long is power lead on neff oven
It does not come with power lead fitted,you will need to fit your own cable,very easy job.
Feb 26, 2009 | Neff U1721 Double circotherm Electric Oven
Change light-bulb
May 17, 2007 | Neff B1421 Electric Single Oven
Neff B1421 Electric Single Oven Logo
56 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
