Question about GPS
My lowrance Elite 4 dsi fishfinder cuts on and after a few seconds cuts off.
Ive checked the battery and it seemed good and I really don't know where to go from here. Ive had it a little over a year so I guess the warrenty has run out. Ive had other problems too with the depth finder but I need to get it to turn on before I can address that problem
  • 508 Answers
Http://www.lowrance.com/en-US/Products/Fishfinder-Chartplotter/Elite4DSI-en-us.aspx
1-You might not be out of warranty
2- try powering the unit up without any of the other accessories plugged into the unit. Sometimes if you have something wrong in something else when the unit powers on it self checks, any problem anyplace when it first boots up will cause it to shut down
3 I don't know anything about these things but have seen other devices where this happens and the problem is usually a faulty add on
Posted on Nov 29, 2013
SOURCE: navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Posted on Feb 24, 2008
hydetech
  • 113 Answers
SOURCE: Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Posted on Mar 17, 2008
CMV9
  • 594 Answers
SOURCE: When turning on the Lowrance
here is the link to your the lowrance web site. the trouble shooting guide says that if you tried to it on another boat than you might need to take it in for service. but there is a section that explains how to do a soft reset on the unit. you might try that.
http://www.lowrance.com/en/Support/Troubleshooting-Guide/Depth-Reading/
please rate and comment on your experiance with fixya.
Posted on Aug 15, 2008
SOURCE: 4150sx finder erratic depth
I had the same problem last time I was out in shallow water (in less than 2 metres of water) and I suspect that the problem was weed wrapped around the transducer but won't know for sure until I take it out on the water again. I had another problem re water temp which I'll enter separately.
Posted on Apr 24, 2009
SOURCE: problem with navman 4150 fish finder
I installed my Navman 4150 depth finder along with the Navman GPS unit when I purchased my Bayliner Trophy 20Ft. Offshore model. Everything was ok for one year and it has been downhill since then. Losing signal, unbelievable high depth ranges, blank periods, etc.. I now can't even get a reading tieded up at the dock. I am now giving up and shoping for a quality unit.. Cape Disappointment.........
Posted on Jul 21, 2009
It works fine for about 20 min.then it starts beeping and alarms ging off sometimes it stops for a few min and then it tarts again I can turn it off and back on and it does good for about 20 min is there a...
I THINK what you're running into here is a poor power connection. (either positive or ground) It would appear to me that as the connection heats up, it is unable to carry the amperage needed to keep the unit running.
Carefully inspect, clean and lubricate with silicone spray the connections, (pay particular attention to the terminals at the power supply AND the fuse holder.)
Hope this is helpful.
-Steve
Mar 30, 2015 | Lowrance Elite-5 DSI Color Combo...
Where should I connect the NMEA data cables from my lowrance elite-5 chirp fishfinder combo unit.
you only use if you connect a radio with long/ lat display or auto pilot. otherwise do not connect them
Sep 22, 2014 | Boating
How do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
Apr 13, 2013 | Lowrance Elite-5 DSI Color Combo...
Cant get the demo mode off my lowrance elite 5 dsi
go to menu click on system find simulator mode click off
Sep 21, 2012 | Lowrance Elite-5 DSI Color Combo...
GPS Logo
136 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
