Question about Dell Inspiron Computers & Internet
Dell laptop error code 2000-0123
Msg:memory-integrity test discrepancy
    Top Expert:
  • Dell Master
  • 22,727 Answers
Run the memory test utility at start up.
Posted on Nov 23, 2013
Pyrhyc
  • 2028 Answers
SOURCE: code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
Posted on Jul 29, 2008
SOURCE: Problems with Dell Inspiron 9400 Video Memory conflict -
This solution is totally incorrect. He is having the problem that many of us face with the GeForce Go 7900 GS and the Inspiron 9400. There is a known issue with eventual overheating and the video card going bad. This is specific to the single-pipeline chip, in which their is a new dual-pipeline style that fixes the cooling/overheating issue that eventually fries the video chip. Dell has not 100% took ownership of this. I am on my fourth fried video card (thank god for the 3-year warranty I got) in which they have previously replaced with the single-pipeline style. This time they are finally replacing the laptop with either a new Inspiron 9400 (better be dual-pipeline chip) or a NEW equivalent laptop.
Posted on Nov 07, 2008
Geekman
  • 32281 Answers
SOURCE: D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Posted on Feb 17, 2009
  • 115 Answers
SOURCE: I have a dell inspiron 1520, today when I was
the problem is with your memory card as one memory module is not functioning which is in DIMM 1. you need to replace it.
because which playing music file as due to damage memory it takes time for buffering. and that is why you hear choppy sound. you can also run a test on memory. Restart the sys. and press F12 on blue Dell Logo. and goto BOOT TO UTILITY PARTITION and run a test on memory it will hardley take 5 mins. and it will give you the result.
Posted on Nov 04, 2009
  • 3940 Answers
SOURCE: Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Posted on Jan 27, 2010
Reducing pc memory usage
I suggest you turn OFF all start up Items on your system, these use the PC memory up as soon as Windows Starts. Stat up Items can be disable from MSCONFIG, Starup and just unclick the Application that needs to stop from running during start-up, NOTE make sure you do not disable any windows application in MSCONFIG start up Items.
Apr 15, 2012 | Dell Inspiron 1545 Notebook
Dear sir , i have a dell inspiron 1464 laptop.i have a problem during window installation.in a diagnostic test there are a error generate. the error code is, Error code 0146 Msg:Error...
Dear questioner after going through couple of posts on dell support forum I found that this problem occurs if your hard drive is not functioning well
If you laptop has warranty please visit the nearest dell store
Aug 06, 2011 | Computers & Internet
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Error code 0334 msg 2000-0334
Looks like you have a dell desktop PC and the error is with the graphic card, remove the card and try it on the integrated display , re seat the card and check if error reoccurs replace card!
Aug 10, 2010 | Computers & Internet
Jan 27, 2010 | Dell Inspiron 6000 Notebook
That message indicates that you did not input during the diagnostic that you could see the test. If the system is running normally, then the error can be ignored.
Dec 28, 2009 | Dell Inspiron 6000 Notebook
I have a dell inspiron 1520, today when I was trying to play a video song it couldn't play in a flow there was some obstruction then I tried audio song and the same problem was happening with that also....
Nov 04, 2009 | Dell Inspiron 6400 Notebook
Graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
Apr 14, 2009 | Dell Inspiron 8500 Notebook
Dell Inspiron 1420 freeze at starting
This is an easy one.
You hard drive has DIED.
Call or chat with Dell tech support and get a replacement drive
http://support.dell.com/support/topics/global.aspx/support/chat/hardware_chat?c=us&l=en&s=gen
Since the system is less that a year old, you can request a replacement drive witht eh factory image on it too.
Jul 14, 2008 | Dell Inspiron 1150 Notebook
Computers & Internet Logo
109 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
