Question about Car Audio & Video
My 2007 ve sv6 commodore stereo stopped working
My stereo and air con controls all stopped at first but now just the stereo isn't working however the bluetooth does. If I press any stereo control buttons on the dash or steering wheel the station display lights up for a few seconds then disappears and no sound. Anyone know what it may be?
  • 3 Answers
Bad connection on cables?
Posted on Nov 23, 2013
3 Suggested Answers
SOURCE: 2004 GRAND CHEROKEE 10 DISC C/D CHANGER MALFUNCTION.
It fixed it's self,the next day the changer was working normal.the battery is weak and going to be replaced.so maybe the problem was low system voltage." IT'S A JEEP THING " ???
Posted on Feb 06, 2009
  • 64 Answers
SOURCE: Pioneer cmx 3000 controller problem The unit
Check the fuses in the main unit. The fuses looks like a resistor, but are marked with "IC" on the print.IC207 (1,5A) and IC209 (315mA) are the one I found to be faulty in a CMX3000 I fixed.
Posted on Nov 27, 2011
My SV6 VE 6 speed auto commodore holds 3rd gear longer than other gears peak traffic - any advice greatly accepted. At the front of the queue - the gearbox changes through all gears perfect - thanks
I would try servicing the transmission, that means a new fluid filter and a fluid drain and refill, it may help. You may have a sticking pressure check valve.
Feb 09, 2017 | Cars & Trucks
2010 Epic. Where is transmission dipstick?
How to check your Transmission Fluid Level - YouTube
? 1:12
https://www.youtube.com/watch?v=zqwbRNQLfSI
Oct 14, 2010 - Uploaded by Robert Callahan
How to check for the proper transmission fluid level. ... Uploaded on Oct 14, 2010. How to check for the proper transmission fluid level ... Then, turn the car off and locate your transmission fluiddipstick. Different cars have ...Missing: epic's
sv6 no transmission dipstick??? :S - Just Commodores
forums.justcommodores.com.au/...holden.../127200-sv6-no-transmission...
Feb 5, 2010 - 5 posts - ‎2 authors
... ive had my sv6 for about 4-5 months now, and i never realised it doesnt have adipstick to check transmission fluid wtf?? my 89' vn has one. ... Just Commodores -Holden Commodore Discussion Forum ... 05-02-2010, 12:07 PM #1 ... As mentioned the 5L40 box in the SV6 & Calais is a sealed unit, so no trans dipstick.
Auto transmission oil DIPSTICK
Dec 23, 2011
Checking 6 Speed Transmission Fluid - Just Commodores
Jun 9, 2011
Too much tranni fluid in my Transmission - Just ...
Mar 25, 2011
4hdd 4L60E - death rattle?
Nov 23, 2008
More results from forums.justcommodores.com.au
Missing: epic's
Nov 30, 2015 | Holden Cars & Trucks
No vacuum at air con vent control knob in vu commodore
check small vacuum hose on rear of square inlet manifold top that goes throught firewall ( bulkhead ) is not cracked or has come off
it goes into cab near heater hoses. this is the vacuum supply hose
if you have no vacuum the heater controls default to go to windscreen. also check the black & white plastic little round one way valve for leaks & operation
also check vacuum hose that goes onto heater tap that is in right inner gaurd under brake master cylinder area for leaks and that its on the heater tap valve
if they are all ok check inside do you hear any hissing noises behind dash controls or down at front centre console area?
Jan 28, 2014 | 1998 Holden VT Commodore
Air con cool for a few days then won't get cool, stop and restart all good
Cars for years have been using a serpentine belt. The compressor only works if the belt is spinning. With the engine running check to make sure the belt is spinning consistently. The alternator or the water pump could be seizing up causing the belt to stop. Check your idler as well. Tension on the belt could be loose and again not turning everything.
Jan 11, 2014 | Cars & Trucks
Ve commodore sv6
What is a Commodore??
Dec 31, 2013 | Cars & Trucks
How to remove the front headrest of Holden 2008 SV6 commodore ?
You need a special tool that slides down the side of the head rest shaft and release the spring clip retainer.
Jul 12, 2012 | Holden Commodore Cars & Trucks
My car's air-con (Tuczon 2007) suddenly stopped thrice! First time (only after 1 year) brought it to a service center and told me its relay just needed cleaning. 2nd time same thing; 3rd time told me...
Hello! You can search replacement part on eBay
Here link for example https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xtucson+2007+air+con+swich.TRS0&_nkw=tucson+2007+air+con+swich&_sacat=0
Jun 19, 2017 | 2007 Hyundai Tucson Limited
Car Audio & Video Logo
190 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
