Question about Ovens
Ceramic hob lights fail but some rings still work
I have an older version of the Indesit VRM640MIX Ceramic Hob (Looks the same, about 5 years old but can't get to see model number) and two days ago while using three of the rings the power light and residual heat indicators went out but the two high power rings are still working, only the two lower power rings don't work, any idea what part could of failed within the hob, when it cools down it works again for a couple of minutes. Thanks
freetek
  • 5568 Answers
SOURCE: NEFF HOB
Your heater is probably equipped with a bimetal thermal switch to prevent overheating and, if it is like most made in China now, it is defective or at least highly inaccurate. If you can locate the device, using a metal shield to divert some of the heat will help it serve its original function as a safety. Look for a thick (4-5 mm), button-like device with two terminals and a diameter of 1.5-2.0 cm.
This point of failure is shared with a majority of drip coffee makers that fail way too early.
Posted on Oct 18, 2008
  • 399 Answers
SOURCE: bottom oven not heating up Fan not working but hasnt worked4 ages
 Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay..... also This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Posted on Dec 06, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
  • 417 Answers
SOURCE: my Candy C5006 electric cooker
The ring that causes the trip out needs to be replaced with a new one.
Posted on Dec 15, 2010
How can you remove burnt plastic from electric hob oven
from the ceramic or glass cook top
will be a slow process cant scratch the top
hope its not tuppa ware
it will smoke
plastic scraper or solid plastic spatula
with hob off .. boiling water little at a time
may have to low heat the hob again
Apr 16, 2017 | Ovens
What products can I use to clean my aeg hg795540xb gas glass top hob? The instructions say neutral products and no hob scrapers
Please, follow this link:
http://www.amazon.co.uk/AEG-Electrolux-50296742005-Ceramic-Cleaning/dp/B002LJDJ7Y
25358477-ou0pu244fjwiiyewsm5u145c-2-0.jpg 6. CARE AND CLEANING WARNING!
Refer to Safety chapters.
6.1 General information
• Clean the hob after each use.
• Always use cookware with clean bottom.
• Scratches or dark stains on the surface have no effect on how the hob operates.
• Use a special cleaner applicable for the surface of the hob.
Dado
Jan 06, 2015 | AEG Ovens
Rented apartment and zanussi ceramic hot is displaying letter L on the hob plate control. There are no manuals around but unit looks new.
The "L" indicates that the child safety lock is on.
You haven't stated which exact model you have, but on most Zanussi's you turn the hob on and then press and hold the + and - buttons together until the display changes from "L" to "0".
Note that on some models you must do this every time you turn the hob on, on some others the lock can be disabled.
Jun 16, 2011 | Ovens
I have a new Defy hob with the colour connections in 4's, but my oven is an older DEFY and has two rows of 6 connectors... please help. How do I connect a new DEFY hob to an old Defy oven?
I have the same predicament. Did you manage to connect your new hob to your old stove? If so, please let us know how to do it.
Thanks.
Mar 04, 2011 | Ovens
My glass cermamic cooktop is burned, i mean literally. Its milk stains or sauce stains all over it. And i cant remove it. There are dark brown stains on it. Please help me
try using a ceramic hob specific scraper to removed the burnt on bits then use a ceramic hob cleaner.
Can you let me know what country you are in and I can send you alternative links.
The following link are for the uk.
https://www.bosch-eshop.com/eshop/bosch/gb/ceramic-hob-cleaning-1.htm
311299 is the most cost effective as it contains cleaner and scraper.
Aug 21, 2010 | Ovens
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Feb 21, 2010 | Ovens
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Jul 15, 2009 | Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
