Question about Cuisinart DCC-3000 Coffee on Demand 12-Cup Programmable Coffeemaker C
Cuisinart DCC-3000 Coffee on Demand reservoir leaks after 1 month of use
My coffee maker leaks continuously out of the coffee reservoir. Tried decaulking and cleaning. No use.
  • 19 Answers
SOURCE: Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Posted on Jan 19, 2008
SOURCE: Cuisinart Coffe Maker has no power
Talked to Cuisinart tech support today and they told me to unplug and leave it for 2 hours... that resets it to the factory defaults. Worked for me...
Posted on Feb 19, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart coffee on demand
There are a couple of possibilities. I would try an unconventional decalcifying process - let 1/2 a caraffe of distilled white vinegar and 1/2 caraffe water sit in the reservoir for a full hour with the coffeemaker unplugged. At the end of the hour, plug the coffeemaker back in and turn it on - once a small amount of vinegar and water brews through, turn the coffeemaker off. Let sit for an additional 20 minutes. Then turn the coffeemaker back on and let the rest of the vinegar/water brew thorugh.
If the machine doesn't take the vinegar/water at all, call Cuisinart and find out if your are still in-warranty. If you are, get the machine replaced. If you are out of warranty, you can remove the bottom of the coffeemaker (difficult), and look at the bottom - likely you will see a loose hose. You can get a Ace Hardware or True Value Hardware salesperson to find an adhesive that will put it back together, or get a generic replacement hose - original parts would not be available except by buying a broken Cuisinart in the same model.
My two cents.
-Tha Mp3 Doctor
Posted on Mar 12, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: coffee pot won't turn on
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
Has bella coffee makers been recalled?
Owner's manual? Call their customer service. Usually they are quite helpful. No Owners manual? Google make model maybe serial number.
Mar 03, 2015 | Cuisinart DCC-3000 Coffee on Demand 12-Cup...
Coffee Maker is leaking
mine was not same make but the upper water tank was plastic and seems they fracture when getting hot too many times .Bunn would not provide a replacement tank so it was buy NEW
Jan 08, 2015 | Cuisinart DCC-3000 Coffee-on-Demand 12-Cup...
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
Coffee pot won't turn on
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart DCC-2000
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
Cuisinart DCC-3000 Coffee on Demand 12-Cup Programmable Coffeemaker C Logo
106 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
