Question about Finis Audio Players & Recorders
No power or light dead - Finis Audio Players & Recorders
Why wont dell i15rv-9762blk wont turn on
Obviously there are no error messages, so it isn't a simple failure.
Several reasons:
1. Dead or damaged battery - look for laptop battery error light or replace battery (borrow a working battery to test)
2. Dead or damaged Power Supply- look for power-on light to confirm operation. Replace PS if dead. (Borrow?)
3. System board failure. No lights/errors messages etc. Place warranty claim.
Aug 10, 2014 | Dell Computers & Internet
My HP G60-230US Computer will not start. The computer is a little more than 2 years old. Every so often when I would start the computer it would say "No boot device found". I would restart the...
sounds like your motherboard malfunctioned. the board was probably starting to go out. thats why it would see the hdd then not.
you sound like youre familiar with computers. you may want to invest in diagnostic cards to troubleshoot problems like this. theyre fairly inexpensive on ebay. basically you insert the card into pci slot and it displays an error code. then you look up the code in a book. works like the obd2 reader for your car.
good luck
Feb 28, 2017 | HP G60-230US Notebook
Tv is turning off and on
There no lamp in the LCD tv only CCFO floorescent light tubes.U can't reset or adjust those CCFO floorescent light tubes.Those CCFO floorescent light tubes are design to work as a whole LCD screen for the tv that it.The tv power supply board is dead.That the board where the power a/c cord plug into it.That the power supply board,it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.On the board u said u see flashing blue light,searches all around for those dead leakages capacitors,they alway bulges up on it tops or puff up on it tops.Replaced those dead capacitors or replaced the whole board.This actions will get the tv power stable again and work.
Jun 03, 2010 | LG 42LC2D 42 in. LCD HDTV
Emerson LC320EM82 S red light will come on and when you go to power the tv on it blinks green and never turns on
Power supply board is dead,if green light on keep blinkings,notthing come on.Power green light is solid,nothing come on.Than ur Tuner signal board is dead.
Feb 09, 2010 | Emerson LC320EM8 32 in. LCD TV
Printer dead, no lights, not powering up at all
your power supply is probably dead you will have to replace it
Jul 19, 2009 | Lexmark X8350 All-In-One InkJet Printer
My D-Link AirPlus Xtrame G is dead
Your power adapter may be dead, check the power connector with a multimeter to see if you have the correct voltage as per the label on the adapter. If not you may only need to buy a power adapter.
You may be able to borrow another adapter with the same voltage and current rating and plug it into your D-Link and if you get a POWER and STATUS lights it proves you have a dead power adapter. If you don't get any lights then it looks like your D-Link is dead.
Nov 25, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
54 people viewed this question
Top Finis Audio Players & Recorders Experts
Are you a Finis Audio Player and Recorder Expert? Answer questions, earn points and help others
