Question about Electrolux EL1022A Ergorapido 2-in-1 Stick / Hand Vacuum
Where is the hole for the charger - Electrolux EL1022A Ergorapido 2-in-1 Stick / Hand Vacuum
2007 dodge charger 3.5 will not start or turn over battery good an the starter is good also what can be the problem?
Check distributor hc leads are in correct firing order for 4piston engine it is usually 1432 also check spark plugs haven't come loose this could be the problem if deisel check injectors for blockage and glowplugs are good
Feb 08, 2013 | Spectre 2007 Dodge Charger - 3.5L V6 - Air...
What can be done to repair a leak from a tiny hole on the bottom of PUR water filter?
I am having the same issue. I've just replaced the filter and it started leaking out of this hole, where it never had before.
I am thinking that maybe the filter isn't seated properly, and that's causing the leak. But I have attached a picture of the hole in question. Any advice would be helpful. Thanks!
Feb 03, 2013 | PUR (FM-9500) Air Purifier
Hand vacuum doesn't charge
If the plug in charger works, the batteries are boiled out and need replacement.
They should not be left on charger all the time. Just charge them for 10 hours and use them until the performance has dropped off, then and only then put it back on charge for 10 hours.
Sep 28, 2012 | Dirt Devil Extreme Power Wet Dry Hand...
Can you use honeywell 12k btu air con in a room with no windows
you can, however the heat from the condenser will recirculate back into the evaporator, you need a place to discharge the hot air, and also the drainage from the condensate. I have cut holes in walls to the outside of the room in many applications with no windows, and they work fine. Just a matter of if you have an outside wall, and how much troble it is to cut the hole, frame the inside of the hole out, get power to the unit and secure the unit in the hole. Hope this helps...
Aug 15, 2009 | Air Purifiers
HOw do i get the red light to go off after changing the filters?
there should be a tiny in hole at the top of the unit. when the unit is on put a pin inside that hole and hold it for about 5 seconds. then release the unit's lights will all come back on and then it should be reset as if you just turned the unit on. if that doesn't work please let me know and i will see what else i can do for you.
Jul 17, 2009 | Bionaire BAP825-U Air Purifier
Red light on holmes 422 hepa filter air purifier.
What is the complete model number of the unit?
Two types of a 422 popped up on their website.
Oct 27, 2008 | Air Purifiers
How to reset air purifier
(from the manual) Turn off the unit. Look just below the last light on the "filter change indicater meter". You'll see a very small hole and the words "reset". Use a sharp object, such as the end of a paper clip (opened up) and stick the paper clip or sharp object into the hole. This is suppose to reset the unit. However, I have heard of cases when people of done what I just described but the indicator late still will not reside to green. I hope this helps you.
Apr 26, 2008 | GE HEPA 106653 Air Purifier
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
Dirty filter
Noggin's solution is correct.  My copy of the BAP825 manual says to poke a paper clip into "the hole marked RESET."  There is no hole marked 'reset' on the air cleaner.  Thanks, Noggin!
Apr 05, 2007 | Bionaire BAP825-U Air Purifier
Electrolux EL1022A Ergorapido 2-in-1 Stick / Hand Vacuum Logo
26 people viewed this question
Top Electrolux Air Purifiers Experts
Richard Lane
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
