Question about Vehicle Parts & Accessories
Engine dies while driving - Vehicle Parts & Accessories
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Hi your problem could be a number of things
I need more info what kind of car the year miles and engine
is there a check engine light . we can start from there.
Posted on Nov 23, 2013
After ideling a while i try to shift into reverse or to drive and it always dies .......any tips or ideas?
engine dies when shifting into reverse or drive - Third Generation ...
www.thirdgen.org/forums/tbi/346079-engine-dies-when-shifting.html
Feb 11, 2006 - engine dies when shifting into reverse or drive ... After it dies it starts right up and idles fine in park or neutral. ... these ignition items because you weretrying to cure the stalling, or, did the stalling occur after you replaced these items? ...The only thing that kept the car running was adjusting the Idle screw up.
Engine Dies When Placed In Gear***Split from Spittybug...EFI ...
dmctalk.org > ... > MAIN FORUMS > Custom DeLoreans/Mods > EFI
Jul 5, 2012 - 18 posts - ‎4 authors
Just to give an update on my car - I've been having an issue with the car stalling when moving from Park into Reverse or Drive (I have automatic). ... I have been playing with the idle advance trying to get more ... I put in the remainder of the AT fluid I had on hand and the car never died on shifting after that.
starts but dies when shifted into drive or reverse - Suzuki Forum
Jan 26, 2016 | Cars & Trucks
My 96 Ford windstar was running just died in the middle of the street I bought a computer thinking that was the problem it cranks but won't fire
Ford Windstar Starting/Stalling Problems - Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Learn more about Ford Windstar at the Edmunds.com Car Forums! ... Then on Friday it died while I was driving down the street. ... I have a 3.8L v6 1996 Ford Windstar. .... Then yesterday the car just died while driving and had to be towed back to .... The engine will crank, start run about 5 seconds then stop.
Fixing A Car That Randomly Dies While Driving - YouTube
? 3:59
https://www.youtube.com/watch?v=zwlruD4JXmY
Jul 20, 2010 - Uploaded by Scotty Kilmer
Fixing A Car That Randomly Dies While Driving. Scotty Kilmer ...Just check it out at https://www.youtube.com ...
2002 Ford Windstar Engine Stalls/Shuts Down While Driving ...
www.carcomplaints.com/Ford/Windstar/.../engine_stalls_shuts_down_wh...
The 2002 Ford Windstar has 11 complaints for engine stalls/shuts down while driving. ... 2002 Windstar just starting shutting off in the middle of driving. ... The engine diesupon acceleration and will crank but won't start unless switch is ... Inspected the Fuel Pump shut-off Switch, Fuel Filter, Run several full tanks of gas ...
Jan 26, 2016 | Ford Cars & Trucks
Drive 20 minutes engine died at engine braked condition engine restarted but dies when auto trans is dropped in drive or reverse
what is the car?
does it have a lock up torque converter for final gear
torque converter is stuck in final drive, lock up or direct drive
you can un plug direct drive to get it going
Nov 02, 2015 | Cars & Trucks
Why did car die while driving on Interstate and will not start back up
When the engine dies all the lights on the dash should come ! It's when the engine is still running an those lights come is when you need to worry ! You need to check for spark an fuel pressure. If no spark probably an ignition module , crankshaft position sensor or distributer module , what ever ignition system it has. If there is spark spray some carburetor clean into the engine , if it try's to start you have a fuel delivery problem , fuel pump , relay ! No Start Diagnostic Basics EricTheCarGuy
May 09, 2015 | 1998 Toyota Corolla Sedan
Xterra 2005 died while driving. Restart and engine would diesel then die. Finally went from dieseling to regular idle. Intermittent problem. Ideas?
I had a 2002 nissan xterra in my garage with the same problem. they all have very common distributor issue on them. replace the distributor with new one
Oct 29, 2012 | 2002 Nissan Xterra
1988 chevy suburban 1/2 ton auto trans; 4 wd; dies after putting into drive
Could be a dirty throttle body or faulty idle air control valve.
Is the check engine light on ?
Jul 09, 2012 | Chevrolet Suburban Cars & Trucks
My 95 3L Lebaron Dies when the car is stopped. It starts then dies immediately, after many cranks with lots a gas it will run. Only happens when cold.
I'd use a gage and check proper fuel pressure, key on engine off. My info says 48 psi.
How long since over-all tune up?
Apr 16, 2017 | 1995 Chrysler LeBaron
Engine dies but starts again but won't continue to run . Was driving home last night and all of a sudden noticedI was losing speed and couldn't excilerate. Pull over and engine died but I could restart it....
You may need a new fuel filter. When you start the engine all the particles in the filter begin to dam up until they choke off the fuel entirely. When the engine dies the particles fall back down allowing enough fuel flow to start the engine and the whole pocess repeats itself. Thanks, Dana
Aug 22, 2009 | 2001 Daewoo Leganza
While driving the engine dies
the problem is in the connections with the unit to the car. check all wires make sure tight and connected. if no problem then let me know.
Dec 28, 2008 | DEI Python 1400XP Remote Start/Keyless...
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
