I have to reconfigure my sharp tv each time i turn it on in order to get sound out of my energy power base soundbar
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
This can happen when you don't use the correct remote control to set the sound options in the sound submenu. If you are using a universal remote there is no option to enter after your selection, so the selection will work until you power cycle the tv. Alternatively, you have the tv on a switched outlet that is being cycled. Putting the tv on a non-switched receptacle should solve this issue.
Posted on Nov 24, 2013
I have a sharp aquos tv, model LC-42D62U, and had a sound bar attached that worked great. When I remove the soundbar I can’t get the TV sound to turn on. I have trouble shot a lot of things. The problem...
I do not have sharp manuals to reference - in general the TV sound - Variable vs Fixed just allows the set to control the volume output (variable) or Fixed will produce one level of output and your device (soundbar) volume control would adjust up or down from there. There is usually another location in the menu that allows you to turn off the TV speakers so they do not operate at the same time as your soundbar or other device. It should be simply Speaker ON / OFF. If you can locate this - you should be able to select it. If it is all greyed out - that means the TV believes based on the connections / setting / input selection - those cannot be changed. (you may try connecting the device and see if the greyed out menu items turn back white or are selectable. Sorry I don't have a specific answer - hope this helps
Dec 21, 2017 | Sharp Televison & Video
Do I need to turn off the tv speakers to get tv sound from my soundbar?
How to Connect Soundbar to TV audio
I would think that the tv would automatically detect a cable being plugged in. It should only send sound to the soundbar once it is connected. Make sure the soundbar is on when you do your testing. You may have to change the audio settings on your tv in order to send audio to the soundbar.
Sep 07, 2016 | Televison & Video
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' Chron.com
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
vizhdtv.com/fix-a-vizio-soundbar-remote-in-4-simple-steps/
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
I have an jbl soundbar and a sharp hd tv. After we connected the sound bar we no longer got a picture or sound.
The two brands should be compatible, and plugging the sound bar in should not affect the picture...either the tv chose that particular moment to go bad, or you plugged the soundbar into the wrong place...look for "audio out" connectors on the tv (should be RCA connectors)...
Jan 01, 2015 | Televison & Video
How do I connect my Sharp HT-SB30 soundbar to Samsung UHD7500 TV
Should be able to use Bluetooth. Need to "pair" the devices (the TV and the soundbar). On soundbar, press On/Standby to power it on, press Input to select Bluetooth (pairing indicator blinks), press & hold pairing button until pairing indicator blinks quickly. Now go to the TV's setup menus: Sound > Speaker Settings > TV Speaker > SoundShare Settings, Add New Device=On, select the Sharp GT-SB30 from device list. If passcode, password, etc is needed, enter 4 zeros (0000). After the devices are paired. the pairing indicator on the soundbar should stop blinking. The pairing information should be retained so you only have to do this one time unless you do a full reset on the TV or soundbar.
Dec 23, 2014 | Samsung Audio Players & Recorders
Can not get sound when connecting a samsung HW f355 soundbar to a sharp aquos 4k tv
There should not be any problem in connecting this TV to Sound Bar. Check all the connections. Contact any service technician to seek help in this matter. Refer the user manuals to both the sets.
Dec 02, 2014 | Samsung Televison & Video
I cant get my energy sound bar to work on this sharp lc46sb54u tv,do i need to use digtal output cable? i have tryed rca cables,no luck.
You have to setup the sound to go to the aux out on the TV. Either digital, Optical or RCA in order for the TV to route the sound to the correct output port.
Apr 27, 2014 | Sharp LC46SB54U 46 in. LCD TV
JBL SB400 Soundbar System
With some TV's you have to go into the menu, and enable an external sound device. If that doesn't work you can try to hook the tivo to the other HDMI inputs to make sure they work. If yes then, it's not your TV it's the soundbar. Hope this helps! Good luck!
Dec 17, 2013 | Sharp LC46SB54U 46 in. LCD TV
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
