Question about Kitchen Ranges
Wolf range hood one light does not work.
How do I check the wiring?
5 Suggested Answers
SOURCE: Wolf Gourmet Range oven lighting delay
UPDATE to Solution #1: I just went to the Wolf Appliance website and found that the recall is still active, at least for the 48" models. Here's the URL: http://www.wolfappliance.com/recall.aspx There are instructions, affected models and serial numbers, etc. You can also call the "Rework Hotline" at 866-643-6408 or send an email to range18.rework@wolfappliance.com
Posted on Sep 04, 2008
MNfisherman
  • 11896 Answers
SOURCE: My pacific hood range has only a black and white
ground wire goes to any metal surface for a ground. Hood, junction box, ect.
Posted on Nov 19, 2009
  • 2696 Answers
SOURCE: 48" wolf gas range - oven works, but broiler does
the ignitor is usually bad.
Posted on Mar 03, 2011
SOURCE: Wolf gourmet gas range/oven 36"--oven lights and
is this a duel fuel unit if so the the electric bake element is open
Posted on Oct 08, 2011
I have a wolf dd36i downdraft cook top ventilator just stopped working it has power and the switch is conected to the remot e
WOLF DD36I USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Wolf Manuals > Cooktop > DD36I
View and Download Wolf DD36I user manual online. ... cooktop. Wolf downdraft ventilation systems are recommended. for use with Wolf electric ... The downdraft will operate most efficiently when ductwork does not exceed 40' (12 m) in length.
Feb 16, 2012 | Viking VIPR101 Kitchen Hood
Sep 19, 2011 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
Whenever i light the gas top wolf range, the ignighters on other burners keep firing
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module.
I hope this helps you to repair the problem with you stove,
Gene
Aug 11, 2011 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
How do you light the pilot light on a Wolf range?
Bottom of oven hold the pilot safety red button down and light the pilot.some times these pilots can be tricky to get to you have to be crafty I have a piece of antenna broke tip off and stuck match right in hole and it worked well.
Dec 27, 2010 | Wolf Manufacturing Gas Kitchen Range
Have a wolf range and the spark generator which lights the burners will not stop clicking even when i turn the stove off. if I turn on the middle back burner it will stop clicking. how do i stop this?
Remove the knobs and skirts and a few screws. Remove the panel and locate the spark switch that is bad by removing one wire at a time till the ticking stops. dfc80e7.jpg
Jul 16, 2010 | Wolf Range CHR-2-1829-FT45 Gas Kitchen...
I just got my (new to me) pre-1990 Wolf 36'' range connected (by a certified pro). 4 burners, 12'' fry top/charbroiler/cheesemelter thingie on left, 4 burners on right, 29'' oven - propane. It has not been...
the oven pilot has 2 setting first setting is for you to light small flame, should not be all yellow if it is it has a dirty orifice inside the pilot hood, you can remove this by disconnecting the pilot line from the hood and removing orifice for cleaning, just rub it with a cloth.once clean and replaced you light pilot and check it out. if its ok turn on oven and secondary pilot will ignite that why it got bigger!! this heats a flame sensor to allow 100% safty vavle to open to let gas into burner so yuo can cook.
Feb 02, 2010 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
Have a Wolf Range Model A-6-9 half the burneres don't light.
I have the same model Wolf Range and need 2 of the Robertshaw SM4 spark modules for it. Robertshaw says they are discontnued. Where can I locate 2 spark modules?
Jul 10, 2009 | Wolf Range Kitchen Ranges
Wolf Range r366 - How do I replace the igniter
I have a Wolf Gas Range and initially my igniter incessantly sparked. I noticed that the igniter is cracked. Do I need to replace it and if so how do I replace it? The electrical wire to the igniter became disconnected; should sticking it back into the igniter cause it to work?
Jun 29, 2009 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
Electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Mar 12, 2009 | Wolf Manufacturing Gas Kitchen Range
This sounds like a problem that was common at the time these ranges were sold -- it prompted a recall:
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02022.html
Hopefully you can still get it fixed. BTW, these ranges were manufactured through 2000 by the Wolf Range Co., which only makes the commercial models now. Residential ranges are now marketed under the Wolf brand by Sub-Zero.
Aug 01, 2008 | Kitchen Ranges
Kitchen Ranges Logo
80 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
