Question about Ovens
Which position is on in firebox Nobel stove - Ovens
How can I remove door?
Hi Tammy:
Many of the older stoves used a similar door hinge system.
When the door is fully opened it can be removed in the following way.
It's much easier with two people.
With one person on each side, lift near the hinge (closest to the stove) then pull away from the stove and at the same time, lift the handle end of the door.
There is a tab and a notch on the hinge arm that has to slide past the retainer.
To re-install, the hinge has to be set for the "door open position".
Slide the hinge arms into the slot so that the tab and slot engage in the correct positions.
Hope this helps.
Cheerfuls. .
Apr 02, 2016 | Moffat Ovens
The door on my Nobel model: Nr.: NF 60 SS/1 will not seal when closed.
Oven doors can warp over time. Also, if the door has a heat shield that covers the window and locks the door during self-cleaning it can become misaligned and prevent the door from closing properly. Minor alignment and adjustment can be done by loosening the screws on the hinges and taking advantage of the slots provided for positioning the door before re-tightening the screws however if the door is warped too much you may not have enough adjustment travel available to properly re-align the door. The metal gasket around the door may also have become damaged and is preventing a proper seal and you might be able to locate replacement gaskets at an appliance parts house.
Nov 19, 2014 | Ovens
Ive been searching for a Nobel Oven Manual NFB60 series with no luck, cazn anyone help me please?
not really sure but try contacting these folks
This is the only link i could find
http://nobel-ae.com/Nobel/ShowProduct.asp?cid=5
Lutfi Trading (LLC)
PO Box :
1430,
Dubai, UAE.
Tel : +971 4 2225335,
Fax : +971 4
2228823
Email Us On:
Sales : lutfigm@emirates.net.ae
Please Click here
for all queries and enquires
Mar 26, 2011 | Ovens
I have Nobel stove approx 18 months old. 5 gas burner with electric stove. Modle FSE 9013M-1 One of teh knobs has broken. Where can I get a relacement?
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 12, 2010 | Ovens
No power to oven or display screen, stove top works
you probably have a bad computer or a power issue...check the connection at the point where the cord attaches to stove and also reset your breaker even if it appears to be in the on position....if connections look good and you have 220 volts @ the stove,your main control...if this happened after self-cleaning-call a tech to your home
Apr 16, 2010 | Whirlpool Ovens
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 | Ovens
Montgomery ward gas stove. top burners work fine. oven barely gets warm
I have a whirlpool gas stove oven fire will not go off when in off position. Is the fire suppose to go off completely?
Aug 21, 2009 | GE JGRS14 Gas Single Oven
Need instructions on how to use a Nobel 60cm electric oven, thank you.
Need an instruction manual for a Nobel oven.
Don't know what all the symbols mean on the oven dial.
Apparently it has heating coil in back of oven as well as at top of oven.
Jul 01, 2009 | Ovens
Oven door falling down on the Frigidaire stove
Try to replace the hinges the locking mechanism is going out
Feb 08, 2009 | Stoves 720EF Electric Double Oven
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
