I have a WF541 Hotpoint 1400 spin which stopped
I have a WF541 Hotpoint 1400 spin which stopped working in middle of cycle it won't pump out, spin or work period, when it stopped the many of the lights were flashing, the lifts come on but machine won't start or do anything had to empty by hand machine just over 5 years old. In desperate need of your help
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
SOURCE: the water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Posted on Mar 28, 2009
  • 160 Answers
SOURCE: hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Posted on Mar 21, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
SOURCE: My Indesit Moon 1400 has stopped working. Shortly
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Posted on Apr 23, 2010
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Spin cycle will not work on siemens xlm 1400 and filter has been cleaned what to do
If the spin cycle is not working, it could be several things. How is it not working? If it won't do anything, i.e. doesn't turn, then I would suspect the transmission since the spin cycle is the high side of the transmission. If it spins but does not take the water out of the unit, then I would suspect, either the pump or the timer.
Good luck and have a great day!
Jun 09, 2011 | Washing Machines
I have a problem with my hotpoint wf340 1400 spin when i put it on it washes but wont come off the wash cycle and will continue washing unless i stop it manually i then have to select pump out and then a...
it is either a broken wire to your heating element or the element itself is open circuit. when the water does not heat the machine will not move onto next stage of wash.
Feb 20, 2011 | Hotpoint Washing Machines
Hi our hotpoint wf541 starts its cycle as normal but doesnt spin and the mini load and reduce crease buttons flash as well as the on/off button, any ideas of how i can fix this thanks.
hi i had the same problem.
its either your filter is blocked or your pump is not working.
after switching the power off, remove the front bottom panel of the machine and unscrew the filter cap on the right behind that panel. check it's intact and clean iside, if not clean it out or replace it and that should fix it. be careful screwing the filter cap back in and make sure its on tight.
to check your pump is working you can pull out the machine and check that water is coming out of the hose by putting it on the pump out / drain cycle after pouring in some water for it to pump out.
Dec 08, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf541 will not finish cycle it wont do a final spin then all the ligts start to flash how can this be fixed
Possibly a blocked filter.
If no filter at bottom front of washer then you need to remove lower rear cover of washer.
Remove l;arge black hose fastened to drum.
Remve and clean filter inside hose.
Remove hose onto pump, and check for obstuction or blockage here as well, and look inside the pump.
If all o/k, and it still does not spin, then it could be for one of several reasons.
Hope this helps solve your prob.
Thankyou
Nov 26, 2009 | Washing Machines
Hi My Hotpoint WF540 1400 spin is stopping mid cycle and not draining, rinsing and spinning unless I stop the cycle and choose just rinse and spin. Any suggestions? sarah
Probably needs the filter cleaning.
Remove lower rear panel.
Remove large black hose onto drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump itself.
Please rate my solution.
Thanks.
Nov 16, 2009 | Washing Machines
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
