Question about JBL Cinema SB400 Soundbar Speaker System with Wireless Subwoofer
Power was off while it was working, not responding at all
I was pressing the power from the remote and I thought it went to standby mode but when I followed all the required steps it' still not responding
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
My matsui tv 28WNO5(A) will not turn on from standby
Try pressing the small reset button on the back, it works, and you will not loose any stored information which caused the unit to go in the stand by mode.
or
Have you tried turning it off for an hour and then turning it back on. This happens to me quite often and leaving it off for a while ususally allows it to come back on. Also have you tried to press the TV/AV button on the remote as sometimes it switches to TV mode when its on standby and then standby won't work as its on TV mode and needs to go back on to AV mode. Basically just press the AV button on the digibox remote and then try standby.
or
if the batteries are removed and left for about 20 minutes before being replaced again, everything works as it should.
or
if any of the above suggestions does not work then you have to open the unit and on the main board of the tv there is a thin mini tube light like component called fuse you will have to replace that fuse .the fuse is very very cheap and you can easily get it at any electronics shop.and if still the unit does not work then there is a major fault in the power supply board and should be taken to the service center for diagnosing the fault that it is repairable or not.but i hope the above information provided will definately help you to solve your problem.
Oct 04, 2008 | Sony KV-32XBR85 TV
How do I power on my midiland mai-760 it's stuck in standby mode
If it is simply stuck in standby mode, try reconnecting the power and pressing the power button from there. If the power button doesn't work, try using the remote. If that doesn't work, try to replace the remote's batteries and try again.
Feb 27, 2017 | Televison & Video
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Denon AVR-3200 wont go into standby mode
Not sure what you mean by standby mode. The power button on most of the audio remotes I deal with merely turns the equipment on and off.
Nov 24, 2013 | Denon AVR-3200 Receiver
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
Dec 10, 2008 | NEC LT 240K Multimedia Projector
JBL Cinema SB400 Soundbar Speaker System with Wireless Subwoofer Logo
70 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
