Question about Sony KV-35V35 TV
Screen is blurred with horizontal lines when 1st turned on. Goes away after 15 mins. Also black cloud appears on screen....moves around then disappears after a few mins. What is going bad?
    Top Expert:
  • Sony Master
  • 74,198 Answers
The fault should be with its supply voltage to video output section circuit. Check this voltage. Check the smoothing capacitor used there. The video output card stage, can be located at the back [neck] of the picture tube, will directly plugged on to it; and can be pulled back out gently. Take care. http://electronicshelponline.blogspot.com/ Check this link for more details. Pull up older posts.
Posted on Nov 24, 2013
  • 1694 Answers
SOURCE: Sony Trinitron 36" TV
Try a "hard reset"===unplug AC for a long time, like overnight.Let me know if there is any change.
Posted on Oct 03, 2007
BMW Rider
  • 232 Answers
SOURCE: Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Posted on Feb 27, 2008
SOURCE: tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Posted on Apr 16, 2008
welcomejee
  • 10594 Answers
SOURCE: My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Posted on Oct 26, 2008
  • 146 Answers
SOURCE: TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Posted on Nov 15, 2008
Monitor distorts colors and goes out of sync horizontally after 15 min
they dont last forever... time for replacement as most are not user-serviceable..
Mar 08, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
Screen, Image, Lines,
Check and replace its LVDS cable [the cable that connects its T'Con board to panel]. Re-seat it once and check, before replace it. Any loose contact with either side of this cable; or the cable itself is damaged, can cause this fault.If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Toshiba 46LX177 46 in. LCD HDTV
Screen goes black or pixelates
viewsonic va1703w screen is starting blur and it is changing colors Screen goes black or pixelates and after 15 to 20 mins by pressing the power on button of the monitor it is getting switched on, and again when restarted it is having the same problem.
Aug 18, 2013 | Dell Computers & Internet
Horizontal lines and blur on touch screen!
The problem is quite simple, ur NDS is getting old. My friend's NDS has the same problenm. You cant do anything, only thing u can do is to replace ur Touchscreen. There are some chinese websites which sell hose for about 15$. May u find hope there.
Mar 23, 2009 | Nintendo DS Lite Console
Screen turns black except for one inch around the outer edge
Use the tv/cap/text button to turn off the text box function of the closed captioning.
Jan 26, 2009 | Sansui COM3101 13" TV/VCR
Convergence
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Pikish Hue and curved colored lines
Sounds like the convergence amp are heating up and going out. you can look for the amps and see if there is a loose connection on the trace and if you can solder you may be able to save them or just replace amps with orginal. This is sometimes caused by moving set around, Set being so heavy it can not take a joult like the direct view sets
Aug 09, 2007 | Hitachi 50UX57B 50" Rear Projection...
Philips monitor problem
Check that the pc to monitor vga lead is not loose at both ends, check your graphics drivers are upto date, although it could well be a monitor fault and replacment required, as don't think they are worth reparing these days
Nov 02, 2006 | Philips Business 104B Monitor
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Televison & Video Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
