Question about Whirlpool Duet GHW9150P Front Load Washer
Problem F13 with Ariston wash/dryer machine ARMF 125
F13 fault showing on my Ariston margarita 2000 awd12 washer dryer and the control Knob keeps continuing to turn endlessly. What could be the problem. Yours desperately John Russell
From memory I think this is a dryer temp. sensor error. Check youtube out with query; "Wash Machine F13 error code". A company in England, eSpares, posts a few vids to help. I've bought a few things from them, very helpful and good prices. I have no connection with eSpares, accept an occasional customer. If you can do it yourself it is a quick, inexpensive fix. Good luck.
H
Apr 03, 2016 | Washing Machines
I have an ariston washer dryer combo. today I turned it on to do a wash cycle. the knob no longer clicks or shows the times of other cycles. I've turned it off and on a few times but nothing helps
Ariston armf 125 washer dryer combo - YouTube
? 4:14
www.youtube.com/watch?v=zPtG5Q3qQ3Q
Oct 23, 2010 - Uploaded by troykm Rinse cycle. Correction - it does do 3 rinse cycles!! :-)
[PDF]Instruction Manual - Ariston Appliances
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf
WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Sep 22, 2015 | Washing Machines
Ariston arwdf 129 error f13 flashing what does its mean?
I've had a quick look through the instruction manual, but was unable to find anything.
http://www.aristonappliances.us/_pdf/manuals/ARWDF129.pdf
Perhaps contact the manufacturer for more information?
http://www.aristonappliances.us/raccontaci.asp
Nov 10, 2014 | Washing Machines
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Lavadora secadora ariston aqualtis aqm8d error f13
F13: NTC wiring harness disconnected from the dryer system
1. Check the efficiency of the terminals on the CNA connector board
2. Check NTC wiring harness
3. Check the wiring harness continuity of the CNA / NTC connectors
4. Replace NTC
5. Replace terminal board
Dado
Apr 08, 2014 | Ariston Technologies AWD 129 NA Washer/...
F13 error code on Ariston washer dryer combo
Model ARMF 125 with same error code F13 how to fix please advise Thks
Nov 06, 2011 | Hotpoint-Ariston ARWDF129NA Washer
Hotpoint wd8200 f13 error code the dryer is not functioning.
My Indesit( Hotpoint/Ariston) list suggests 'reduced airflow, check fan motor and filter' and 'dryer NTC (thermostat to us!) and connections', the latter requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
