Question about 2004 Dodge Stratus - Sedan - Weathershield HP Car Cover
2004 dodge stratus want turn over clicks like a dead battery
It crank twice and i tried to start it again and it want do anything now it just sounds like i need a boost off but the last couple of days before it stopped cranking when it cranked with a little rattle to it and stopped very quickly whats the problem now
  • Fernando Segovia Jun 01, 2014
    Take the battery to AutoZone Auto Parts and have them check it. It the battery has a low charge, AutoZone employee will charge the battery overnight. Both testing and charging are at no cost to you. After your battery has been recharged overnight, go back to AutoZone and have them test the battery while you are there. That way you can see for yourself if the battery is good or needs replacing. They will explain all the hows and whys to you. After you have resolved the battery issue, make sure that your battery cable connectors on your car are clean and free of any corrosion before you install and reconnect the battery. Also, goes without saying, make sure you tighten the battery cables properly onto the battery. Hope this helps.
    Master:
  • 602 Answers
Check the wire connections on the starter If the small one is loose the starter solenoid will not engage the starter and you get a click like a dead battery. Several rapid attempts will usually get it going.
Posted on Nov 24, 2013
I have 2005 I changed the starter and battery good but it still won't start
First does it crank, if it does then check to see if the fuel injectors are getting fuel.....could be a fuel pump...
second....if there is nothing when you turn the key and the battery is good and the starter was replaced...it could be a bad ground.....thats the ground coming off your battery and goes to your chassis of the car.........let me know how you make out.
Sep 24, 2015 | Dodge Stratus Cars & Trucks
Door ajar clicking on off
when you turn the key do lights on the dash come on before trying to start? if it goes click after you turn it further than to on then it sounds like a dead flat battery. get a jump start and let run for 15 mins-half an hour then turn it off and try again. if it doesnt at least crank then its likely a battery that cannot be saved and needs replacing.
Oct 07, 2012 | 2004 Dodge Ram 1500
I have a 2004 dodge stratus that has power to lights but does not turn over when i try to crank even after jumping it off.
Hi.
Check ignition switch fuse. This is a 20 Amps. see that it has not blown. In 2004 Fuse should be nr 8 in the power box under the hood (newer models #24).
Once you are sure that battery, fuse and wires are OK, check starter and ignition switch. Check if there is 12V to starter while cranking. If there is power and the starter motor does not turn, then the motor is gone.
If there is no power to starter motor when you crank, then the ignition switch located inside the steering column may need replacement. Before repairing, try reading error codes with a code scanner.
Apr 15, 2011 | 2004 Dodge Stratus
Starter not turning over after engine has heated up
Yes the starter is going outreplace asap. it has a short that is only there when it is hot. things expands in the starter
Jun 18, 2010 | 2001 Dodge Stratus
Car won't crank
sounds like a starter problem ,check the relay going to it ,otherwise bad starter.
Feb 25, 2010 | 1999 Dodge Intrepid
My friend has a 2004 Dodge Stratus and it will not start. Instead, there is an annoying clicking or tapping noise when the key is turned. Is that a problem with the alternator or battery?
Sound as if battery is dead. Battery will need to be checked and recharged. If battery checks out as good, might want to remove alternator to have it checked to be sure that the alternator is also good.
Nov 17, 2009 | 2004 Dodge Stratus
Car wont start. lights and everything comes on but no crank when I try to start car. been having to start car twice to get it to turn on. 1999 dodge intrepid
Look into the starter motor.
Car is 10 years old and starter motor problem is linked to startup issues in cars. Common issue
May 29, 2009 | 1999 Dodge Intrepid
Will not crank
Did you replace the starter relay yet ?
A quick and repeated clicking sound, like a mini machine gun firing sound is usually a dead battery or bad electrical connection, but it could also be a bad starter relay.
You sound experienced enough to know if you see a corroded wiring connection this would be a sign of a bad connection.
Are you sure the new battery has enough charge in it to turn the car over? Try jump starting it just in case.
Good luck and keep us posted.
Jan 20, 2009 | 1995 Dodge Stratus
2004 stratus won't start
try checking the fuel pump or replace the spark plugs and wires because most dealers put cheapos on them
Dec 05, 2008 | 2004 Dodge Stratus
2004 Dodge Stratus - Sedan - Weathershield HP Car Cover Logo
61 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
ptpumpman
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
