Question about Ovens
Instructions cannon 10287g
How can I turn off auto and set the time
2 Suggested Answers
  • 189 Answers
SOURCE: Cannon 10287G gas - lower oven flame no longer
Nope- It's most likely the ignitor. Resistance should be above 4ohms. Accessible below drip pan. 40-75$ local app. parts store. Hope this helps- ED
Posted on Mar 01, 2010
Testimonial: "Thank goodness someone knows - the manufacturer offers no technical support! Keep up the good work."
Hi, I've tried to programme my cooker on auto following the instructions, everything works apart from when the time comes to turn the oven off automatically it doesn't work. The buzzer goes...
Are you sure it's the oven still running and not the built in cooling fan...next time look at the fan at the rear of the oven if it's not turning it's off and you will be hearing the cooling fan
Oct 08, 2017 | Ovens
I've read the "getting started" instructions regarding the auto matic switch on and it doesn't seem to make sense. I can get it to turn off automatically but not on. Sorry for being dim.
Firstly, make sure the actual time is correct. Set the oven (if it's a double oven the clock function will only work on the main oven) to the setting and temp required. The first timer setting you put in is the cooking duration (not the start time) ie if it's a casserole that you want on low for a couple of hours, adjust the first setting to 2:00, when you press for the next setting you will see the the timer has already added 2hrs to the current time, adjust this to the time you want the item to finish (eg, You want it ready for 6pm, adjust to 18:00). Don't press anything else, give it a second or two and the oven will switch off. The oven will switch on 2hrs (or whatever time you have set) before the end time. Whilst the oven is waiting to switch back on, on some models the cooling fan will run continually, this is normal. If you are a little slow enter the times the clock will time ut and return to the actual time.
Hope this helps
Feb 21, 2013 | Neff Ovens
The electrical mains switch was turned off. When I turned the oven back from the mains , the oven turns on but does not generate heat. I think it is something small do with my settings. Can u help....
If it has a timer, then when the power was on again, it probably reset to auto, you need to reset it to manual cooking
Refer to your instruction book if you have one.
Otherwise it is a question of pressing 2 or more buttons at the same time on the timer to reset it to manual
Feb 12, 2011 | Gaggenau EB 270/271 Electric Single Oven
Cannon 10287G gas - lower oven flame no longer comes up from low level start up level. is this the thermostat, please?
Mar 01, 2010 | Belling XOU270 / XOU271 Electric Single...
How do you set the clock on an electrolux premier built in single oven after a power cut as time is flashing and auto is showing and only four buttons and no instruction manual.
hold down the first two buttons on the far left then turn the little diel button,this will set the time.also you can set the timer useing one button hope this helps roscargou.
Feb 15, 2010 | Electrolux Ovens
I need the instructions for a diplomatic double fan oven as the second oven is set on auto timer and I can't get it to work.
i had the same prob..... manual operation, to set the programmer to manual (cancelling any auto setting),press the cook time and ready time buttons simultaneously.
To set time of day, press the cook time and ready time buttons simultaneously and keep the buttons depressed. Use the plus and miuns buttons to the the time. A(auto symbol goes out cookpot symbol comes on.
Mar 27, 2009 | Ovens
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Oven wont turn on due to auto mode.Cannot cancel auto mode.
If you have followed instructions properly, and cannot get it off auto. then you will need a new timer, alternatively, the timer can be bypassed
Dec 07, 2008 | Ovens
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
