Question about Ovens
Morning peeps, i have just recently replaced my element is a diplomat electric oven, as it has not been heating up. the little light on the front panel does not light up either someone said it may be the thermostat but i dnt want to spend money if it is not that... any help is welcome cheers
    New Friend:
  • 14 Answers
Check voltage for 220 volts and wire connection.
Posted on Nov 23, 2013
4 Suggested Answers
  • 1462 Answers
SOURCE: electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
Posted on Apr 16, 2007
Maytag317
  • 1136 Answers
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Posted on Jun 20, 2009
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
I have a diplomat 3300 the oven stopped working but the grill still works.what will the problem be?
IS IT GAS OR ELECTRIC? GAS YOU MAY HAVE CLOGED LINES ELECTRIC YOU MAY HAVE A HEAT ELEMENT THAT HAS GONE OUT AND NEEDS TO BE REPLACED. TRY TO FIND A MANUAL ON LINE TYPE IN BRAND NAME ALONG WITH MODLE NUMBER TO SEE IF YOU CAN FIND A MANUAL.
Jan 31, 2015 | Ovens
I have a diplomat oven - i turned it on this afternoon and whilst the fan revolves there is no heat coming from it! i tried the grill and this works fine and heats up! what could the problem be pls??
It sounds like the oven element is blown and needs replacing. If the oven fan and the indicator light are coming on it will be the element or possibly a burnt off wire at the oven element terminals.
Mar 12, 2011 | Ovens
I have a diplomat 4510 electric oven, the pilot light is constaintly on even when the oven is not on,the oven does not heat up, i recently replaced the element
If you have replaced the element, and it does not heat up, then I would suspect the thermostat as being the cause of the problem, more so if it is the oven pilot light that is on.
To be certain, you really need to see if you are getting a feed to the element when you you set the thermostat.
Hope this helps.
Jan 31, 2010 | Belling XOU592 / XOU593 Electric Double...
Oven not working
fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Jan 12, 2010 | GE Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Hbn7052gb/05
If you have a BOSCH electric Cooker or Fan Oven which isnot heating it could be one of the following problems.
1, If the fan motor in the back of the oven is goinground and the temperature light is on (normally little red light), but there isno heat then you will probably need a new oven element, these are generallyvery easy to fit and readily available from our website these can be testedwith a electric meter.
To gain access to the BOSCH element you will have to remove the back platefrom inside the oven. Once removed you will see the fan and element,if you look closely at the element you will probably see a small holeburnt in it where it has blown. Sometimes however there is no evidence of afault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your BOSCH fan oven is getting warm but takes avery long time to cook or is burning the food more on one side than the other,then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into theoven then you need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your BOSCH oven thermostat
4, A quite commonand easily overlooked answer is if your BOSCH oven is not working at all ie: no heatand no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Jul 30, 2009 | Bosch HBL 5032 Electric Single Oven
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 | Ovens
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
