Question about Sony Cyber-shot DSC-W100 Digital Camera
DSC-W100 "Shaky Hand" icon and taking infrequent pictures
Hello my camera which I adore has become irratic lately, when I am review pictures it will all of a sudden switch back to camera mode but most disturbingly as of last night it really won't take pictures. In 'P' mode it shows a shaky hand icon and refuses to take a picture for at least 15 secs if at all. In all other modes it isn't taking pictures at all. I've "restarted" it several times, Im afraid the warrenty might be out so taking it to Sony might suck. Any help appreciated. S
    Problem Solver:
  • 13 Answers
Re: DSC-W100 "Shaky Hand" icon and taking infrequent...
You restarted it by turning it off and on again?
Try re-initializing your camera. Menu --> Setup 1 --> Initialize "OK"
I hope that helps.
As for switching back to camera mode, that could be your selector switch. Mine is weird to, it takes pics fine but the selector switch is touchy and thinks i'm turning it when I'm not. It does this most often in Auto mode, probably because I use it most. You might try putting it in another mode before reviewing pics.
Posted on Jun 02, 2008
0 characters
3 Points
How to put Date on Photos from a Sony DSC W100 Read more: Date on Photos from a Sony DSC W100 |
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Sep 18, 2012 | Sony Cyber-shot DSC-W100 Digital Camera
Dsc-w100 window cracked/ no picture
sony cyber dsc-w100,not dsc-w55
I drop the camera and the window broke. where can I find a window.?
Dec 07, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Mar 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Shaky hand symbol and bad quality photos
good day,
to disable/enable the "shaky hand" symbol of your camera, just select the Picture Stabilization icon on the dial on top of the FinePix F30.
i hope this helps.
Oct 12, 2008 | Fuji FinePix F30 Digital Camera
I found a solution that worked for me further on in this site. The person said to reset the camera. On my Sony DSC-W100, I opened the battery/memory slot door and to the left of the memory slot there's a tiny gray dot that I pressed and the problem has gone away.
Jul 20, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Sony DSC-W100
This address has the LCD screen for W100 for 49.99 plus 7.99 shipping. I had the same problem with my w100. Just remove the screws that hold the back on. Gently take out the LCD screen and follow the connection to where it connects. Gently pop open the connector clamp, its hinged on the far side. remove the old replace the new snap connector clamp back down. Check that it works then put back and screws back on.
Jul 10, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
DSC-W100 not taking pictures
possible ribbon from CCD image to main board not seated properly
Nov 29, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
it can be possible to select reset icon by selecting menu option.
it is not possible to take this type of pictures because at auto flash mode the subject can't be covered witin flash range .therefore picture may underexposed however the forground within flash range may correctly exposed.If we do all this at flash off mode the motion of subject will appear  as blurred due to slow shutter speed.
Oct 04, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Problem taking pictures
The only solution is to ask the help from Authorized Sony Service. If you need more info please advice. Arpi
Feb 26, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Sony DSC-W100
I think ya camea has developed a hardware fault.. maybe time for the camera Shop fixit man ... I found a manual maybe that'll B some help?
Jan 27, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
172 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
