Question about ION Audio Ipa16 Block Rocker AM/FM Portable Speaker System for
Schematic diagram power supply
Blown PSU when connected 220 with 110 selected
  • 60 Answers
IT SOUNDS LIKE YOU MAY HAVE BLOWN YOU CAPACITORS AND OR OTHER COMPONENTS, FIRST CHECK THE FUSE. IF YOU HAVE A MULITI METER IT SHOULD READ AROUND 0 OHMS
Posted on Nov 25, 2013
Power supply circuit diagram
There is almost certainly a reason the PSU has blown, these are not very reliable units and the amp has probably gone and taken the PSU with it. You are better off taking it to a dealer and getting it fixed. If there is no power on the seecondary and there is no short the transformer must have blown (assuming you're not trying to check with a DC meter)
Jan 19, 2014 | Mackie Srm450v2 Srm450 Srm 450 V2 Active...
I need trace schematic or diagram for power supply board PLCD300PS07
I have the same PS - did you ever get a diagram ? I'm after one too....resistor R100 completely blown so I can't read its value but its either 900Ohm or 100Ohm ?
We might be able to compare symptoms....
Feb 26, 2013 | Televison & Video
Where can I find a schematic diagram fot Enermax EG465P-VE ATX
You can't found any diagram for and specific ATX PSU
but there are some generics
Dec 01, 2012 | Computers & Internet
I turned on the TV and it popped and went off and will not come back on
Hi.
When that happens you have usually blown the PSU. The power supply is the board connected to the power cord. If there had been a pop sound, power went off, and now TV is completely off, then the PSU has blown.
There is a 6 Amp 125 VAC fuse in the AC section of the PSU, that is the first part to check.After that test the PSU. Sometimes it is even possible to spot a blown capacitor in the PSU board. They look bulged, sometimes burnt and in some case you can even see a leak. Sometimes is instead possible to see a burnt area that is revealing a short, often in the AC section of the PSU. The PSU is located at the back of the TV. Power must be disconnected before removing back panel. Do not touch PSU. Capacitors can store and release heavy discharge even with power cord not connected. There are also 3 small brown fuses located next to the flyback. Those can be tested using a multimeter. Testing must be done by a trained person.
The PSU cannot be easily replaced with a new one. The part is not in stock anymore (part number was 264102), and it is not even easy to find on Ebay. The PSU must be repaired.
Regards.
Ginko
May 24, 2011 | RCA HD52W59 HDTV Projection Television
Panasonic 53wx53g is flashing led 5 times. This indicates an ic4511 issue. I read to check voltages into the board. There is none on the 2.5, 5, or 9v lines. There is also none on the 20v supply coming out...
If there are No voltages, this can be from two reasons, either there is None,because the power supply has "Blown" an important component, or there is a fault, elsewhere in the TV circuitry, that is shutting down the power supply. If all connections are removed and the PSU, still will not give power, it is most likely the PSU itself. If it DOES give power, you have some sort of short circuit that is shutting down the PSU, you will have to find that first. Also there may be some "Other" component that has "Blown" the PSU, that "Cause" will have to be found first or as soon as a new PSU is put in, it will simply be destroyed. Us engineers earn our salt..
Mar 03, 2010 | Televison & Video
Whining sound with xion 800 watt power supply.
There is a fan insine the power supply, and also a fan on the CPU. Occasionally there is also a fan on the chassis of the computer itself.
Turn on the computer, take the case off, and listen to identify the source of the noise. If it's inside the PSU, return it and get a new one.
Feb 20, 2009 | XION PSU XION|XON-800R14N 800W RT
I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
Jan 20, 2009 | StarTech.com (ATXPOWER250) 250-Watt Power...
Schematics or diagram for a 480W PSU
I need a schemetic diagrm D15-1013/diablo ATX 250w Power supply
Thanks Louie.
Dec 18, 2008 | Computers & Internet
ION Audio Ipa16 Block Rocker AM/FM Portable Speaker System for Logo
259 people viewed this question
Top ION Audio Players & Recorders Experts
Bentley Self
Level 1 Expert
Mark Mc
Jay Plesset
Are you an ION Audio Player and Recorder Expert? Answer questions, earn points and help others
