Question about Epson Stylus Pro 9600 InkJet Printer
Epson 9600 suddendly stopped printing yellow
I have a 3 yr old Espon 9600...has been printing fine....ran two prints perfectly. Next day everything printed with a purple cast. Did nozzle check and found no yellow was printing at all! Right before this I had put in a full new yellow cartridge...printed a few good prints then nothing. Did numerous cleanings and nozzle check along with 1 power clean. Still nothing! Of course Epson wants $1500 to just look! One tech said it may be a bad cartridge...any ideas?
  • 1 more comment
  • Anonymous Mar 07, 2008
    Could you please explain a little better how to get to the pad under the print head?
  • ketan dalwala Jun 04, 2008
    Problem with dumper ,ink supply and finally print head.
  • Anonymous Sep 24, 2008
    We have the same problem couple months ago.  After changing the button battery on the back of the printer, everything went fine.
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Posted on Oct 28, 2007
    New Friend:
I was away from my Epson 9600 stylus pro printer for a few weeks and when I came back I did a nozzle check and the printout was only printing all of black some of yellow and nearly all of light black. after K2 clean it remained the same. this head is 4 months old and the damper kit is also new. I soaked the damper in purified water and left it for a few days. when I tried again I got the same black results. this time the only other coler was the yellow nozzle and it was orange. any suge
Posted on Apr 24, 2011
We have the same problem a couple months ago. After changing the button battery on the back of the printer,  everything were back to normal.
Posted on Sep 24, 2008
SOURCE:
What does error message 100001C0 mean?
100001C0
AC disruption (AC Power) (Unplug and wait 30 sec., then plug back in)
Thursday, 10 July 2008
Epson 4800 Error message - Service req. 100001C0
I was printing quite happily on my Epson 4800 one evening recently, but the next morning the automated nozzle check sent by Harvey Head Cleaner did not print and there were a couple of flashing red LEDs and the printer's LCD display was saying "Service req. 100001C0". What to do? I was about to set off for the day job so I just had to leave it flashing away as I had no idea what to do, but fear the worst...
I did a quick web search that evening and found very little, but a couple of posts seemed to think that turning off the printer was the solution.
I had a look at the Espon Field repair guide that I have and found the following in the error codes section:
100001C0
I have the printer plugged into a
power surge protector block so there should not have been any problems and no other equipment was saying that there had been a power outage, but...
So I turned off the printer and left it for a day while I got on with the day job again. When I turned on the printer there was a lot of whirring while it went through its "auto something or other" routine (see previous postings for my thoughts on this) which I watched with a lot of trepidation as this often converts a perfect nozzle check into one with one of more colours completely missing.
Eventually it told me to press pause and then went into it's "Ready" mode.
I ran a nozzle check and it came out perfectly, so all was well again.
May 27, 2014 | Epson 4880 Stylus Pro InkJet Printer
Printer will only print purple
on a colour printer, black is mixed with the other colours. Try printing a black and withe photo and you always get a colour cast. If your black cartridge is empty or the nozzles are blocked, you get bad colour and fussy prints.
test all nozzles, like is explained in the manual.
Check, if you know how to do, if nothing fell in the printer, that is now on the print head. Sometimes just dust or paper scraps are picked up by the printhead, making it difficult for the printer to print a normal page.
Apr 15, 2014 | Epson PX730WD Stylus Photo
Color differences
i apologize for the inconvinience.
the possible reason why its printing the right color, is bec. some of the nozzles might be clogged by dried inks, so when inks come out, the combination of colors are not balance. try printing a nozzle check first, if the nozzle check have gaps or breaks, try head cleaning, nozzle check after it so you can see if it improve or still w/ gaps, just do nozzle check, head cleaning, then nozzle check, head cleaning alternately until no more gaps then try to print.
Printing a nozzle check pattern
Load paper in your printer
In SelecType mode, press the Paper Feed (fontu1.gif) or Paper Feed (fontd1.gif) button until TEST PRINT is displayed on the LCD panel, and then press the SelecType button.
Press Paper Feed (fontu1.gif) or Paper Feed (fontd1.gif) button to display NOZZLE CHECK
Press SelecType button to display PRINT
Press the Enter button. The nozzle check pattern is printed as shown below. After printing, printer exits the SelecType mode and return to the READY status.
Nozzle check pattern examples:
good
yoi.gif head cleaning necessary
headcleaning: press the cleaning button for 3 seconds
Feb 10, 2010 | Epson Stylus Pro 9600 InkJet Printer
Different ink settings banding
Try doing a printer head alignment, sounds like the printer heads are overlapping causing the banding.
Screen colors also never match perfectly to the print either, whist your monitor can produce millions of colors, the printer can only do some many.
Aug 30, 2009 | Epson Stylus Pro 9600 InkJet Printer
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Epson r300 - banding problems on print out
Nozzle check is fine? I am not sure. Check again. There is transverse and vertical lines. Is it perfect? Turn off printer, move head to center, put wet tissue with hot water at head cleaning mech. (pad). move head to parking position, wait for 15 minutes, repeat for 3 times. Check nozzle.
Jun 11, 2009 | Epson Stylus Photo R300 InkJet Printer
Trying to get my Espon P860A Stylus Color printer to print out
Please do a printer check first. Print out a nozzle check pattern.
Trash and re-install the epson printer software. The driver for your product is downloadable fromt the epson.com site.
Apr 29, 2009 | Epson Computers & Internet
HP PSC 1200 color problems with website prints
It strabge... Anyway u just clean your print heads and nozzles... it shuld make it fine... or just replace ur catridge...
Sep 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
Epson Stylus Pro 9600 horizontal banding problem
the banding is a result of clogged head. I had the same problem and fixed it with many cleanings.
Jul 12, 2008 | Epson Stylus Pro 9600 InkJet Printer
Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Mar 07, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
880 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
