Question about Frigidaire Refrigerators
How to replace thermostat westinghouseRJ422T-R fridge
    Problem Solver:
  • 16 Answers
Check on utube
Posted on Nov 25, 2013
Fridge is freezing everything
raise the thermostat setting to 4 ( 1 is near zero c)
if it still does it have the thermostat replaced
Nov 12, 2017 | Refrigerators
Refrigerator whirpool is only working after tapping on the front control system panel? which part has to be replaced?
Whirlpool side by side fridges with the control panel across the fridge section have thermostats that will fail. Tapping on that control panel will cause the fridge to work temporarily. You will need to replace the refrigerator thermostat if you see small black specks under the thermostat.
Oct 21, 2016 | Whirpool Refrigerators
Kenmore fridge, 59665932403, Froze up.
Could be an ice buildup behind the fan, in the air passageways or around the fridge thermostat.
Could also be that the DEFROST thermostat needs to be replaced.
Sep 09, 2016 | Kenmore Refrigerators
Fridge too cold
Return your thermostat to 5 setting. If this does not help, it is probably the contacts inside the thermostat are welded shut and needs to be replaced. You can find you replacement thermostat with your model number on Searspartsdirect.com.
Sep 25, 2014 | AEG Refrigerators
The refrigerator runs almost continually for no apparent reason. It started a few days ago. We have changed nothing.
There are four likely reasons:-
If it is not a frost free refridgerator, the thermostat is iced up and not sensing temperature - defrost the fridge.
The thermostat is faulty and in this case the contents of the fridge should be freezing up - replace the thermostat.
The gas is low in the system and the fridge should then be warmer than normal and the thermostat is trying to compensate by having the compressor running constantly - re-gas the fridge.
The door seal is leaking or the door is not closing fully, allowing cold air to escape - check the seal and the door and correct or replace the seal.
Please rate this response.
May 21, 2011 | Refrigerators
Why does the fridge part of my zanussi freezone fridge/freezer, keep freezing the food?
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 24, 2010 | Hoover HCA390FFK Bottom Freezer...
Replacing a fridge thermostat of a Smeg FC40RX fridge freezer
DO NOT ATTEMPT THIS METHOD UNLESS YOU UNDERSTAND ELECTRICAL SAFETY. The thermostat is behind the cooling element at the back of the fridge compartment and it connected to the dial at the top front of the compartment that controls its temperature setting. Remove the front plate to access the switch and you will see the wiring that goes to the thermostat. Connect the two wires to the thermostat and if the fridge does not start the thermostat is faulty. Replacements are available, but you may need to do some hunting on line. With the power off this time, securely tie a few feet of string around the thermostat wiring at the switch. carefully loosen the cooling element to free the thermostat and pull it free. Now tie the string to your new thermostat and pull the string back through so the wiring is pulled into place. Put everything back the way you found it and, after a short while, enjoy a nice cold drink.
May 12, 2010 | Refrigerators
I have the same problem.
test thermostat. when fridge is running, turn dial to lowest setting , fridge should turn off. then when fridge is not running,turn to highest setting, fridge should turn on. if it fails this test thermostat is faulty and needs to be replaced
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Refrigerators Logo
77 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
