Question about Health & Beauty
Rascal 600 scooter 4 wheeler
Steering colum slack and too much play when trying to turn
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 168 Answers
Sounds like you need to tighten the nuts, they do some times work loose.
Posted on Dec 05, 2013
  • 61 Answers
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Posted on Mar 19, 2010
SOURCE: I have a Rascal 245 Mobility Scooter which is 3
Obtaining a 4-wheeled front section is the best way to improve stability. The 3-wheeled front section on rascal 235 and 245 scooters easily detaches and interchanges with the 4-wheeled front sections(235 models are a little shorter (less legroom).
Posted on Oct 03, 2010
  • 2418 Answers
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
Posted on Apr 12, 2011
  • 692 Answers
SOURCE: Low hour, RASCAL 600
The green light on your charger indicates a full charge but you know thats not right since you didn't charge the batteries when they were in storage they have dropped so low the charger cannot detect them and provide a charge. The batteries will need to be replaced with new ones. Charge before use and charge for at least 20 days to get them operating at 100% now you will have to use it for those 20 days to get the batteries used to charging charge every night when you go to bed and unplug when you get up in the morning. If you do have to leave the chair for a week or so put up fully charged and charge once a week overnight. If you put the chair in storage again disconnect the batteries from the chair and store with a full charge. Hope this helps you
Posted on May 08, 2011
gopakumarg43
  • 74211 Answers
SOURCE: Rascal 240 scooter Battery charged ,scooter
Hello
There is an overload protection switch in it. It will look like the the protection switch that can be seen under the mixes. The picture of the overload protector is added here. Its press button will only seen outside. Just putsh it once and check. The motor has carbon brushes inside it to get armeture contact. If these burshes are worn out, the motor won't turn, and the scooter won't move. There will be two of them in opposite directions. They are replacable parts. The picture of it is also given here. Check these first. If you need anymore assistance from me, feel free to get me by FixYa.
gopakumarg43.gifgopakumarg43_0.gif\
OK
Posted on Aug 05, 2011
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
Wiring schematic rascal 600 24v electric
hi, firstly what controller is fitted (curtis) ? then i can give you a ideal controller wiring schematic but you won't get hold of a Rascal one..
Regards
Rob
www.gewizrepairs.co.uk
Aug 16, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
How to reset a rascal control panal
To reset the control panel turn the key off then back on. If you are receiving a flash code, once the the code has been corrected restarting the with the key will reset the control panel.
Scooter Doctor App
Jun 01, 2014 | Rascal Used Electric Power Wheelchairs -...
What kind of chargers can i use for rascal 600
I would recommend the correct automatic charger as you don't want to damage your batteries or have a fire/explosion.
Mar 27, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal 600T Scooter FIX IT Manual
There is an owners manual available which has a troubleshooting guide at the following: http://manuals.monsterscooterparts.com/mobility/Rascal/manual-rascal-600-t.pdf
If you have a good relationship with a local dealer they may be able to copy and provide you with one.
Electric Mobility, the manufacturer, in my experience will not provide one to you.
Mar 02, 2014 | Electric Mobility 3 Wheel Motorized...
Starter switch
I would contact your Rascal dealer for a replacement key switch.
You could try spraying some switch cleaner in the key slot and work the key to see if it is just dirt but I would imagine it is worn out.
May 06, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
3 wheel rascal 600 blinks 4 - 8 times...what does it mean?
Good day to you.These series or blinks or bleeps are codes to determine the fault.& the trouble you will find is Shoprider etc will not give out info to the public.Contacting a Scooter repair shop is a good idea,reason being.They can order your part if needed.You can also download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as a PDF File,if you do anything yourself.Remember a repair shop will be hesitant to even look at it & I suggest you take a photo of every step if fixing yourself with your mobile.Have a nice day,hope I was of help.Colin
Mar 31, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal 600 wiering diagram
Hi Carol, I have lots of Rascal answers at my link, also check the Rasca pics, the is a Diagram there. but if you have a specific problem you can post there or here, we will do are best for an answer. Scooter Doctor App
Mar 18, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
I have a Rascal 245 Mobility Scooter which is 3 wheeled. How can I make it more stable than the little caster wheelers they use?
Sep 24, 2010 | Golden Technologies Golden CompanioN II -...
Health & Beauty Logo
55 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
